08-17-2016 05:03 AM
Hi team
i want to check warranty of my Cisco device so we can extend warranty with you and i have check with your tool warranty finder. This tool not provide correct information. So, please provide right tool for me so we can check ;warranty status of my Cisco devices.
Dharam vir
08-17-2016 05:25 AM
Go HERE.
Log in using the correct CCO login. Enter a valid serial number one by one or by bulk.
11-25-2016 02:12 AM
what is link to CCO login? thanks
11-25-2016 08:45 AM
see the text "Go HERE." - just right below Leo's avatar in his message :-)
03-28-2018 08:20 PM
Thanks Leo.
08-15-2018 06:44 PM
09-14-2021 03:18 PM
09-14-2021 11:57 PM
Hi there,
First, you will need to have a Cisco account to be able to log in to https://cway.cisco.com/sncheck/
I've sent you a PM with a screenshot of the aforementioned device warranty status.
Martin
03-11-2019 12:21 PM
This is by far the worst website i have ever been on to check a warranty. Lenovo products on the Lenovo website are so much easier. It's as simple as a link on a page and when you open it, you type in a serial number and poof it simply says "yes" or "no". You guys should try this out, here are all your problems.
1. You are making it seem as though you need a login to do it (apparently you can use a guest format and don't need to create an account which leads to next problem)
2. You can't sign in as a guest or the guest feature is **bleep** near impossible to find (I believe you it's there, i just refuse to work that hard to find it)
3. When you do sign in there is no where to check the warranty (I clicked the "here" it signed in and again no where to type the serial number
4. Finally found a link to check for a warranty, wait that's not to check a warranty, its to actually just put in a sku not a serial number so you can sell me the next warranty. Shouldn't you check if i still have one first)
All in all i find your website to be garbage and impossible to find anything i need
10-04-2019 11:31 AM
It is not as user friendly but it is possible to search for things by specific serials. It's hidden among the other Tools & Resources at https://cway.cisco.com/sncheck/
10-08-2019 02:10 PM
This looked promising... but didn't work. I put in known good serial numbers, but it came back saying nothing was covered. This is on units that are even less than a year old.
07-08-2020 09:02 PM
Same here. Came looking to check some serials for warranty coverage and have been stuck in a labyrinth of terrible user interfaces an apps.
Check out the Dells site for comparison https://www.dell.com/support/home/en-au. A google search finds this page as the top result, you enter serial, it tells you everything you need to know. Literally 10 seconds and you're done.
I've been trying for half an hour on Cisco's site and still no luck. The checker site linked above says nothing even through I have valid serial numbers.
09-14-2021 12:35 PM
This is really great you find this link and shared here, really helpful. Many thanks.
09-14-2021 12:37 PM
very well said "worst website i have ever been on"
06-24-2019 11:48 PM
