Hello Sulaiman,
What you need to do is to upgrade the switch to higher firmware than 1.4.7.06 (just upgrade to latest - 1.4.9.4):
Here is the link to release notes:
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf20x_sg20x/release_notes/R_1_4_7_06_RN.pdf
• Security enhancements:
- Disabled support for TLS v1.1
- Disabled support for the following weak SSL ciphers:
- Cipher suites offering no authentication
- Cipher suites offering no encryption
- weak-ciphers below 64 bit
- cipher suites using DES
- cipher suites using 3DES
- cipher suites using RC2
- cipher suites using RC4
- cipher suites using MD5
- SSH enhancements:
- Removed support for following weak ciphers: aes256-cbc, arcfour, aes128-cbc, 3des-cbc, and aes192-cbc
- Added support for following ciphers: aes128-ctr, aes192-ctr, and aes256-ctr
- Removed MAC hmac-md5
Hope it helps
Cheers,
Mike
