10-28-2012 11:57 PM
Good Day. I need to ask if what is the main difference between an SD208T and SF90D. Aside from the price in which SF90D cost lower than that of the SD208T and that SF90D has replaced the SD208T, what else does these two differs?
Thanks.
Solved! Go to Solution.
10-29-2012 08:26 AM
Hey there Rey, here is one post that is in progress you may want to keep an eye on
https://supportforums.cisco.com/message/3771164
But, to answer the inquiry, the SD208T-NA does not have a replacement transition to SF90 for the NA (North America models). The replacement model for the NA version is the SF100D-08-NA.
The SD208T-EU, KR, UK have a tranisition model to the SF90D-08-AS, SG and KR respectively.
Are you interested in the EU, KR, UK models or the North America / Australia transitions?
-Tom
Please rate helpful posts
10-29-2012 08:26 AM
-Tom
10-29-2012 05:48 PM
Hi Thomas,
Good Day. Thanks for your reply. The explains it all. Actually my question came from one of my colleagues. We were just stuck to the question as to how these two unmanaged switch differs with each other.
Best Regards,
