SFP Module Support List for RV160x and RV260x Devices
Small form-factor pluggable (SFP) ports are included on the RV160 and 260 routers to allow the use of optical SFP transceiver modules. SFP’s convert the optical signals to electrical signals. SFP’s allow the handling of higher data rates. SFP ports empower SFP switches to connect various Ethernet and fiber cables through the network. There are also various types of SFP modules to suit your network’s needs. This article provides a complete list of officially supported SFP Modules and customer tested SFP Modules.
IMG 1 – An RV160W router with an SFP port
Official Supported SFP Modules:
SFP Module
Product Description
MGBSX1
Gigabit SX Mini-GBIC SFP Transceiver
MGBLX1
Gigabit Ethernet LX Mini-GBIC SFP Transceiver
MGBLH1
Gigabit LH Mini-GBIC SFP Transceiver
GLC-BX-U
1000BASE-BX10-U Upstream Bidirectional Single Fiber; with DOM
GLX-LH-SMD
1000BASE-LX/LH long-wavelength; with DOM
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/RV260/SFP/SFP_RV260x.pdf
Customer Tested SFP Modules:
SFP Module
Replacement for Cisco:
Product Description
Tested by:
SFP-LX/LH
GLC-LH-SMD
1G / 20KM / 1310NM
TenFourOptics
SFP-BX-U
GLC-BX-U
1G / 1000BASE / 20KM / TX-1490NM / RX-1310NM
TenFourOptics
SFP-BX-D
GLC-BX-D
TenFourOptics
SFP-T
GLC-T
1G / 100M / COPPER / RJ45
TenFourOptics
SFP-SX
GLC-SX-MMD
1G / 500M / 850NM
TenFourOptics
SFP-EX
GLC-EX-SMD
1G / 40KM / 1310NM
TenFourOptics
SFP-ZX
GLC-ZX-SM
1G / 80KM / 1550NM
TenFourOptics
SFP+ / SR
SFP-10G-SR
10G / 300M / 850NM
TenFourOptics
SFP+ / LR
SFP-10G-LR
10G / 10KM / 1310NM
TenFourOptics
SFP+ / BX UP
SFP-10G-BX-U-20
10G / 20KM / 1270 / 1330
TenFourOptics
SFP+ / BX DOWN
SFP-10G-BX-D-20
TenFourOptics
SFP+ / ER
SFP-10G-ER
10G / 40KM / 1550NM
TenFourOptics
SFP+ / ZR
SFP-10G-ZR
10G / 80KM / 1550NM
TenFourOptics
SFP-10G-T-C
GLC-10G-T
10GBASE T / RJ45 / 30m / CAT6A / CAT7
TenFourOptics
IMG 2 – A Customer Tested SFP module attached to a router.
IMG 3 – Customer Tested SFP Module attached to a router with fiber optic cables attached
These are just some of the supported SFP Modules that may work on the Cisco RV 160 and 260 Series routers. We would love to expand this list and see if there are any other SFP Modules that our customers use. Please comment down below if you see an SFP Module not on this link and you worked with it. We also welcome any discussions on the SFP modules above. What are your thoughts and experiences with SFP on Cisco Business Routers and Switches?
