11-19-2020 10:16 AM
I have enabled Single Number Reach (SNR) on Cisco Configuration Assistant and is working as expected, desk phone and mobile phone ring, I have the option to pick up a call from any device. But I find this kinda annoying that when I pick up the call on my mobile device the desk phone keeps on ringing. Is there a way to make the desk phone stop ringing when the call is picked up on the mobile device?
Thank you
Solved! Go to Solution.
11-20-2020 04:35 AM
Hello Luis,
This is the default behavior and you can't modify it by CCA. However, you can configure the "snr ring-stop" command under ephone-dn configuration mode to stop the ephone from ringing and to place the phone on hold. This will allows you to stop the IP phone from ringing after the SNR call is answered on a mobile phone. See section "Configure Single Number Reach Enhancements on SCCP Phones" on the following guide:
Martin
11-20-2020 04:35 AM
Hello Luis,
Martin
