Cisco IP phone SPA-301
Mesrop
Hello friends.
How can i set new IP Address on SPA-301 IP Phone,using phone buttons?
Sorry, I missed the matter. You can't configure IP via IVR. You can discover current IP via IVR then use WWW UI to configure it. But it's rather recovery procedure - phone uses DHCP (by default) to obtain IP address, thus IP is assigned by it and you need no IVR/WWW to configure it manually. Or you can arrange complex zero-touch deployment environment. Even virgin phone can be fully provisioned with no manual intervention of user required.
Dan Lukes
Did you missed Using the Interactive Voice Response Menu on the Cisco SPA301 paragraph of User Guide ?
I am already seen that paragraph,but i didn`t seen,that how i can change my Phone IP address from 0.0.0.0 to other IP.
Thank you dear Dan.
