Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
187
Beginner
Cisco IP phone SPA-301
Hello friends.
How can i set new IP Address on SPA-301 IP Phone,using phone buttons?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Engager
Re: Cisco IP phone SPA-301
Sorry, I missed the matter. You can't configure IP via IVR. You can discover current IP via IVR then use WWW UI to configure it. But it's rather recovery procedure - phone uses DHCP (by default) to obtain IP address, thus IP is assigned by it and you need no IVR/WWW to configure it manually. Or you can arrange complex zero-touch deployment environment. Even virgin phone can be fully provisioned with no manual intervention of user required.
4 REPLIES 4
Engager
Did you missed Using the Interactive Voice Response Menu on the Cisco SPA301 paragraph of User Guide ?
Beginner
I am already seen that paragraph,but i didn`t seen,that how i can change my Phone IP address from 0.0.0.0 to other IP.
Engager
Beginner
Thank you dear Dan.
