Hi, how can I set login password on Cisco SPA504 IP phone? When I login, I can change user password and it works (I can't login to phone without password), but problem is that this block keys on the phone also...? Which is default admin password?
Hello @zhex
I found a thread that might help you find the answer to your question, since it was accepted as a solution.
With best regards,
JS
