Cisco uc500 voice mail
shiran.wang
Cisco uc500 one phone can not retrieve internal extension voice messages,(with this error message "this mailbox is in use")
but you can hear external voice messages
That is in the CUE. On a UC-500, you would have a "intergrated-service-engine" interface.
You need to session through/into that with the "service-module integrated-service-engine x/y session" command. Once you do this, you would be in the CUE module. That's where you will run the command.
5 Replies 5
R0g22
Can you run the following command in the CUE CLI ?
#voicemail mailbox unlock owner test (replace test with the actual UserID of the user)
If you have access to the CUE GUI, you can do the following -
Go to >>>voicemail>>>>mailboxes>>>>check the box for the user and click to unlock
Post above, verify from the mailbox settings whether it is YES or NO.
My OS have no this command
CPKZHCME#voicem
CPKZHCME#voice?
voice
CPKZHCME#voice?
voice
CPKZHCME#voice ?
dnis-map Load a dnis-map
CPKZHCME#conf
CPKZHCME#configure t
Enter configuration commands, one per line. End with CNTL/Z.
CPKZHCME(config)#tele
CPKZHCME(config)#telephony-service
CPKZHCME(config-telephony)#vo
CPKZHCME(config-telephony)#voicemail ?
WORD voicemail access number
CPKZHCME(config-telephony)#do sh ver
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(2)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 23-Oct-10 08:04 by prod_rel_team
issue was solve use the command as you suggest.
thanks for your help
Great! Cheers!
