12-23-2017 04:04 PM - edited 03-20-2019 10:22 PM
Desperately looking for a configuration example to configure back lit 7970 phones on my UC540 to stay backlit 24/7. ive tried entering commands for active days and length to no avail. if someone could be as kind to provide me with an example i would appreciate it. ive tried this several times with no success.
Solved! Go to Solution.
12-26-2017 06:51 AM
You should be able to use the "service phone" commands under "telephony-service" such as:
Router(config)# telephony-service
Router(config-telephony)# service phone backlightOnTime 00:00
Router(config-telephony)# service phone backlightOnDuration 24:00
Router(config-telephony)# create cnf-files
Router(config-telephony)# reset all
Be aware that the parameters are case-sensitive.
Brandon
12-26-2017 06:51 AM
Brandon
12-26-2017 08:30 AM
wow amazing that worked! thank you so so very much! rated! you have a great new year!
