Multiple incoming calls in a SPA514G
John Martin
Good morning everyone,
I have a problem and I'm not sure how to solve it. I try to explain.
I have a UC540 with severals SPA514G and everything works fine.
Now we have added a sip trunk in the UC540 and it also works well but the problem
is as follows, the sip tunk has 6 channels, so 6 calls can enter simultaneously in
the worst case. Well, the problem is that the SPA514 only allows 2 calls per line
and if there is a third one, it appears that the line is busy.
As I said, I only setup one of the 4 possible lines configured, and I can not
assign the same extension in the 4 four lines.
Can someone help me on how to get more calls in an SPA514G IP phone simultaneously?
Thank you very much in advance.
John Martin
Hello again,
I think that I have found a solution.
When I register a line of my SPA514G in my UC540, there is a opcion to forward call to another extension if the line is busy.
Therefore, I will register the four line of my SPA514G, 210, 211, 212 and 213. Each line support 2 calls as maximun.
If there is a incoming call, I forward call always to extension 210, but if the line is busy, I will setup the option "Call forward busy: " to extension 211.
If I use this filosofy, my SPA514G could receive incoming calls up to 8 as maximun.
For me, it is a good solution. isn't it?
Thank you.
bijpraka
Go to the phone web page:
http://IPADDRESS/admin/advanced
Now go to Voice->Phone->Miscellaneous Line Key Settings->Call Appearance Per Line
Set this from 2 to 10 or whatever number suits for your purpose.
After this the phone will be able to handle more than 2 calls.
Thanks.
Hello
Thank you for your help but my SPA514G hasn't this web page http://IPADDRESS/admin/advanced
404 Not found !
Maybe formware version?? My phone uses firmware 7.5.2
Kind regards.
or on LCD go to settings->network configuration->web server.
Make sure that the web server is enabled and retry.
If its already enabled try try https?
Thanks.
