12-15-2020 10:57 AM
Hello.
Looking to update a SPA504G's firmware. However there is no EXE file in the download package like prior releases.
Can Cisco provide a tool to install the BIN file since the client does not use provisioning on their SPA504G devices.
Much Appreicated.
Solved! Go to Solution.
12-15-2020 03:37 PM - edited 12-15-2020 03:37 PM
Provisioning maintains the phone configuration, it doesn't upgrade firmware. So it's irrelevant the client is not using the provisionig.
Just configure "Upgrade Rule" to contain a URL where the .bin file can be fetched by phone.
01-06-2021 02:18 PM
Thanks for the suggestion. I finally got around to doing it via a http server just over a week ago. It was not hard, but for some reason call encryption no longer works. I ended up downgrading to version E so encryption would work.
Thanks again,
Wilson.
