12-19-2017 09:24 PM - edited 03-20-2019 10:22 PM
Hello. recently replaced my UC20 with a UC540 and now seem to have slow download speeds in the 30mbit range. the UC520 would test at my full connection download of 70mbits down. not sure what has changed. i have factory defaulted the UC540 twice but issue persists. Attached is my configuration. can someone take a peek at this for me
------------------ show running-config ------------------ Building configuration... Current configuration : 35211 bytes ! ! Last configuration change at 00:16:06 EST Wed Dec 20 2017 by keith ! NVRAM config last updated at 10:10:25 EST Fri Dec 15 2017 ! version 15.1 parser config cache interface no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption service internal service compress-config service sequence-numbers ! hostname UC_540 ! boot-start-marker boot-end-marker ! ! enable secret 5 <removed> ! aaa new-model ! ! aaa authentication login default local ! ! ! ! ! aaa session-id common ! clock timezone EST -5 0 clock summer-time EDT recurring crypto pki token default removal timeout 0 ! crypto pki trustpoint TP-self-signed-439657943 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-439657943 revocation-check none ! ! crypto pki certificate chain TP-self-signed-439657943 certificate self-signed 01 3082023C 308201A5 A0030201 02020101 300D0609 2A864886 F70D0101 04050030 30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274 69666963 6174652D 34333936 35373934 33301E17 0D313731 31313330 34303635 385A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F 532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3433 39363537 39343330 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100 AC0873CA 91A1BD0D EAB1C9A7 CA667D52 DC027D1A 00EA0A44 C6B5AE6B B5098DF6 4D2E757F FD678232 0A6733CF F5C12868 4931B134 1F6C149A 23C7E821 8D3F2339 AACD9691 EA53EA88 BB2A05EC 41FC2A9F B7A75935 012EE89D 2458470D ED1A0745 7775C188 F009A820 DFC6F191 7431AA06 ECFBD117 17DC809B 9211D700 FAE5C13F 02030100 01A36630 64300F06 03551D13 0101FF04 05300301 01FF3011 0603551D 11040A30 08820655 435F3534 30301F06 03551D23 04183016 801485F3 083F954D BCC8D401 FD873CAA AA56DD29 8C50301D 0603551D 0E041604 1485F308 3F954DBC C8D401FD 873CAAAA 56DD298C 50300D06 092A8648 86F70D01 01040500 03818100 59E35326 4FC5A557 9E4769B4 6D0838D3 92B77254 B9015817 4F0F926E 9D7AA85B 241A04BD 8AB05CFC A90C731F A1FF3999 B978EABA 59D4407A FA161D8C 06827232 669F9F4F 72187B29 2E66ACD3 DAFF7046 A3DDEC70 AF0B2BD3 FFED333F 79416E19 9EA2A83B 9CE1EE53 3639CE35 2BCC0596 055D3FD5 B1797741 C0E114BB 320D8376 quit dot11 syslog ! dot11 ssid cisco-data vlan 1 authentication open ! dot11 ssid cisco-voice vlan 100 authentication open ! ip source-route ip cef ! ! ip dhcp relay information trust-all ip dhcp excluded-address 10.1.1.1 10.1.1.9 ip dhcp excluded-address 10.1.1.241 10.1.1.255 ip dhcp excluded-address 192.168.10.1 192.168.10.9 ip dhcp excluded-address 192.168.10.241 192.168.10.255 ! ip dhcp pool phone network 10.1.1.0 255.255.255.0 default-router 10.1.1.1 option 150 ip 10.1.1.1 ! ip dhcp pool data import all network 192.168.10.0 255.255.255.0 default-router 192.168.10.1 ! ! ! ip name-server 84.200.70.40 ip name-server 84.200.69.80 ip name-server 8.8.8.8 ip name-server 8.8.4.4 ip inspect WAAS flush-timeout 10 ip inspect name SDM_LOW cuseeme ip inspect name SDM_LOW dns ip inspect name SDM_LOW ftp ip inspect name SDM_LOW h323 ip inspect name SDM_LOW https ip inspect name SDM_LOW icmp ip inspect name SDM_LOW imap ip inspect name SDM_LOW pop3 ip inspect name SDM_LOW netshow ip inspect name SDM_LOW rcmd ip inspect name SDM_LOW realaudio ip inspect name SDM_LOW rtsp ip inspect name SDM_LOW esmtp ip inspect name SDM_LOW sqlnet ip inspect name SDM_LOW streamworks ip inspect name SDM_LOW tftp ip inspect name SDM_LOW tcp router-traffic ip inspect name SDM_LOW udp router-traffic ip inspect name SDM_LOW vdolive no ipv6 cef ! multilink bundle-name authenticated ! stcapp ccm-group 1 stcapp ! stcapp feature access-code ! stcapp feature speed-dial redial **# ! ! ! stcapp supplementary-services port 0/0/0 hold-resume fallback-dn 2008 port 0/0/1 fallback-dn 2007 ! ! ! ! trunk group ALL_FXO max-retry 5 voice-class cause-code 1 hunt-scheme sequential ! ! voice call send-alert voice rtp send-recv ! voice service voip allow-connections h323 to h323 allow-connections h323 to sip allow-connections sip to h323 allow-connections sip to sip supplementary-service h450.12 sip no update-callerid ! voice class codec 1 codec preference 1 g711ulaw codec preference 2 g729r8 ! ! voice class cause-code 1 no-circuit ! voice register global ! ! voice user-profile 1 user Ndraco password whiterain number 3301 type normal ! voice user-profile 2 user Jjerris password whiterain number 3302 type normal ! voice user-profile 3 user Bpopp password whiterain number 3305 type normal ! voice user-profile 4 user Ddonuts password whiterain number 3306 type normal ! voice user-profile 5 user GStation password whiterain number 3307 type normal ! voice user-profile 6 user Tpost password whiterain number 3308 type normal ! ! voice translation-rule 1000 rule 1 /.*/ // ! voice translation-rule 1112 rule 1 /^9/ // ! voice translation-rule 2001 ! voice translation-rule 2002 rule 1 /^6/ // ! voice translation-rule 2222 rule 1 /^91900......./ // rule 2 /^91976......./ // ! voice translation-rule 3265 rule 1 /\(^.*$\)/ /9\1/ rule 15 /\(^ABCD$\)/ /ABCD\1/ ! ! voice translation-profile CALLER_ID_TRANSLATION_PROFILE translate calling 1111 ! voice translation-profile CallBlocking translate called 2222 ! voice translation-profile INCOMING_CallerID_PROFILE translate calling 3265 ! voice translation-profile OUTGOING_TRANSLATION_PROFILE translate called 1112 ! voice translation-profile XFER_TO_VM_PROFILE translate redirect-called 2002 ! voice translation-profile nondialable translate called 1000 ! ! voice-card 0 ! fax interface-type fax-mail ! ! license udi pid UC540W-FXO-K9 sn FGL161424DL archive log config logging enable logging size 600 hidekeys username Keith privilege 15 secret 5 <removed> ! ! ip tftp source-interface Loopback0 ! ! ! bridge irb ! ! ! ! interface Loopback0 description $FW_INSIDE$ ip address 10.1.10.2 255.255.255.252 ip access-group 101 in ip nat inside ip virtual-reassembly in ! interface FastEthernet0/0 description $FW_OUTSIDE$ ip address dhcp client-id FastEthernet0/0 ip access-group 104 in ip nat outside ip inspect SDM_LOW out ip virtual-reassembly in load-interval 30 duplex auto speed auto ! interface Integrated-Service-Engine0/0 description cue is initialized with default IMAP group ip unnumbered Loopback0 ip nat inside ip virtual-reassembly in service-module ip address 10.1.10.1 255.255.255.252 service-module ip default-gateway 10.1.10.2 ! interface FastEthernet0/1/0 switchport mode trunk macro description cisco-wireless spanning-tree portfast ! interface FastEthernet0/1/1 switchport voice vlan 100 macro description cisco-phone spanning-tree portfast ! interface FastEthernet0/1/2 switchport voice vlan 100 macro description cisco-phone spanning-tree portfast ! interface FastEthernet0/1/3 switchport voice vlan 100 macro description cisco-phone spanning-tree portfast ! interface FastEthernet0/1/4 switchport voice vlan 100 macro description cisco-phone spanning-tree portfast ! interface FastEthernet0/1/5 switchport voice vlan 100 macro description cisco-phone spanning-tree portfast ! interface FastEthernet0/1/6 switchport voice vlan 100 macro description cisco-phone spanning-tree portfast ! interface FastEthernet0/1/7 switchport voice vlan 100 macro description cisco-phone spanning-tree portfast ! interface FastEthernet0/1/8 switchport mode trunk switchport voice vlan 100 macro description cisco-switch ! interface Dot11Radio0/5/0 no ip address shutdown ! ssid cisco-data ! ssid cisco-voice ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0 station-role root antenna receive right antenna transmit right ! interface Dot11Radio0/5/0.1 encapsulation dot1Q 1 native bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Dot11Radio0/5/0.100 encapsulation dot1Q 100 bridge-group 100 bridge-group 100 subscriber-loop-control bridge-group 100 spanning-disabled bridge-group 100 block-unknown-source no bridge-group 100 source-learning no bridge-group 100 unicast-flooding ! interface Vlan1 no ip address bridge-group 1 bridge-group 1 spanning-disabled ! interface Vlan100 no ip address bridge-group 100 bridge-group 100 spanning-disabled ! interface BVI1 description $FW_INSIDE$ ip address 192.168.10.1 255.255.255.0 ip access-group 102 in ip nat inside ip virtual-reassembly in ! interface BVI100 description $FW_INSIDE$ ip address 10.1.1.1 255.255.255.0 ip access-group 103 in ip nat inside ip virtual-reassembly in ! ip forward-protocol nd ! ip http server ip http authentication local ip http secure-server ip http path flash:/gui ip dns server ip nat inside source list 1 interface FastEthernet0/0 overload ip nat inside source static tcp 192.168.10.32 80 interface FastEthernet0/0 80 ip nat inside source static tcp 192.168.10.32 443 interface FastEthernet0/0 443 ip nat inside source static tcp 192.168.10.32 3478 interface FastEthernet0/0 3478 ip nat inside source static tcp 192.168.10.32 3479 interface FastEthernet0/0 3479 ip nat inside source static tcp 192.168.10.32 3480 interface FastEthernet0/0 3480 ip nat inside source static tcp 192.168.10.32 5223 interface FastEthernet0/0 5223 ip nat inside source static tcp 192.168.10.32 8080 interface FastEthernet0/0 8080 ip nat inside source static udp 192.168.10.32 3478 interface FastEthernet0/0 3478 ip nat inside source static udp 192.168.10.32 3479 interface FastEthernet0/0 3479 ip nat inside source static udp 192.168.10.32 3658 interface FastEthernet0/0 3658 ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0 ! logging esm config access-list 1 remark SDM_ACL Category=2 access-list 1 permit 192.168.10.0 0.0.0.255 access-list 1 permit 10.1.1.0 0.0.0.255 access-list 1 permit 10.1.10.0 0.0.0.3 access-list 100 remark auto generated by SDM firewall configuration access-list 100 remark SDM_ACL Category=1 access-list 100 deny ip 192.168.10.0 0.0.0.255 any access-list 100 deny ip host 255.255.255.255 any access-list 100 deny ip 127.0.0.0 0.255.255.255 any access-list 100 permit ip any any access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_7## access-list 101 remark SDM_ACL Category=1 access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any access-list 101 deny ip 10.1.1.0 0.0.0.255 any access-list 101 deny ip 192.168.10.0 0.0.0.255 any access-list 101 deny ip host 255.255.255.255 any access-list 101 deny ip 127.0.0.0 0.255.255.255 any access-list 101 permit ip any any access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_5## access-list 102 remark SDM_ACL Category=1 access-list 102 deny ip 10.1.10.0 0.0.0.3 any access-list 102 deny ip 10.1.1.0 0.0.0.255 any access-list 102 deny ip host 255.255.255.255 any access-list 102 deny ip 127.0.0.0 0.255.255.255 any access-list 102 permit ip any any access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_7## access-list 103 remark SDM_ACL Category=1 access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000 access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000 access-list 103 deny ip 10.1.10.0 0.0.0.3 any access-list 103 deny ip 192.168.10.0 0.0.0.255 any access-list 103 deny ip host 255.255.255.255 any access-list 103 deny ip 127.0.0.0 0.255.255.255 any access-list 103 permit ip any any access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_23## access-list 104 remark SDM_ACL Category=1 access-list 104 permit udp any any eq 3658 log access-list 104 permit udp any any eq 3479 log access-list 104 permit udp any any eq 3478 log access-list 104 permit tcp any any eq 8080 log access-list 104 permit tcp any any eq 5223 log access-list 104 permit tcp any any eq 3480 log access-list 104 permit tcp any any eq 3479 log access-list 104 permit tcp any any eq 3478 log access-list 104 permit tcp any any eq 443 log access-list 104 permit tcp any any eq www log access-list 104 deny ip 10.1.10.0 0.0.0.3 any access-list 104 deny ip 10.1.1.0 0.0.0.255 any access-list 104 deny ip 192.168.10.0 0.0.0.255 any access-list 104 permit udp any eq bootps any eq bootpc access-list 104 permit icmp any any echo-reply access-list 104 permit icmp any any time-exceeded access-list 104 permit icmp any any unreachable access-list 104 deny ip 10.0.0.0 0.255.255.255 any access-list 104 deny ip 172.16.0.0 0.15.255.255 any access-list 104 deny ip 192.168.0.0 0.0.255.255 any access-list 104 deny ip 127.0.0.0 0.255.255.255 any access-list 104 deny ip host 255.255.255.255 any access-list 104 deny ip any any log ! ! ! ! snmp-server community <removed> RO tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin tftp-server flash:/phones/7942_7962/apps42.8-5-4TH1-6.sbn alias apps42.8-5-4TH1-6.sbn tftp-server flash:/phones/7942_7962/cnu42.8-5-4TH1-6.sbn alias cnu42.8-5-4TH1-6.sbn tftp-server flash:/phones/7942_7962/cvm42sccp.8-5-4TH1-6.sbn alias cvm42sccp.8-5-4TH1-6.sbn tftp-server flash:/phones/7942_7962/dsp42.8-5-4TH1-6.sbn alias dsp42.8-5-4TH1-6.sbn tftp-server flash:/phones/7942_7962/jar42sccp.8-5-4TH1-6.sbn alias jar42sccp.8-5-4TH1-6.sbn tftp-server flash:/phones/7942_7962/SCCP42.8-5-4S.loads alias SCCP42.8-5-4S.loads tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads tftp-server flash:/phones/7945_7965/apps45.8-5-4TH1-6.sbn alias apps45.8-5-4TH1-6.sbn tftp-server flash:/phones/7945_7965/cnu45.8-5-4TH1-6.sbn alias cnu45.8-5-4TH1-6.sbn tftp-server flash:/phones/7945_7965/cvm45sccp.8-5-4TH1-6.sbn alias cvm45sccp.8-5-4TH1-6.sbn tftp-server flash:/phones/7945_7965/dsp45.8-5-4TH1-6.sbn alias dsp45.8-5-4TH1-6.sbn tftp-server flash:/phones/7945_7965/jar45sccp.8-5-4TH1-6.sbn alias jar45sccp.8-5-4TH1-6.sbn tftp-server flash:/phones/7945_7965/SCCP45.8-5-4S.loads alias SCCP45.8-5-4S.loads tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml tftp-server flash:/ringtones/RingList.xml alias RingList.xml tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw tftp-server flash:/ringtones/Bass.raw alias Bass.raw tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw tftp-server flash:/ringtones/Chime.raw alias Chime.raw tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw tftp-server flash:/ringtones/Pop.raw alias Pop.raw tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw tftp-server flash:/Desktops/CampusNight.png tftp-server flash:/Desktops/TN-CampusNight.png tftp-server flash:/Desktops/CiscoFountain.png tftp-server flash:/Desktops/TN-CiscoFountain.png tftp-server flash:/Desktops/CiscoLogo.png tftp-server flash:/Desktops/TN-CiscoLogo.png tftp-server flash:/Desktops/Fountain.png tftp-server flash:/Desktops/TN-Fountain.png tftp-server flash:/Desktops/MorroRock.png tftp-server flash:/Desktops/TN-MorroRock.png tftp-server flash:/Desktops/NantucketFlowers.png tftp-server flash:/Desktops/TN-NantucketFlowers.png tftp-server flash:Desktops/320x212x16/List.xml tftp-server flash:Desktops/320x212x12/List.xml tftp-server flash:Desktops/320x216x16/List.xml tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au tftp-server flash:/Desktops/TieDye.png tftp-server flash:/Desktops/TN-TieDye.png tftp-server flash:/ringtones/DoubleRing.raw alias DoubleRing.raw tftp-server flash:/ringtones/Happy.raw alias Happy.raw tftp-server flash:/Desktops/OceanLove.png tftp-server flash:/Desktops/TN-OceanLove.png tftp-server flash:/ringtones/Statef.raw alias Statef.raw tftp-server flash:/ringtones/Pickmeuplove.raw alias Pickmeuplove.raw tftp-server flash:/ringtones/WrongCawr.raw alias WrongCawr.raw tftp-server flash:/ringtones/BitsOGlassMuffin.raw alias BitsOGlassMuffin.raw radius-server attribute 31 send nas-port-detail ! ! control-plane ! bridge 1 route ip bridge 100 route ip ! voice-port 0/0/0 timeouts ringing infinity station-id name General caller-id enable ! voice-port 0/0/1 timeouts ringing infinity station-id name General caller-id enable ! voice-port 0/0/2 station-id number 4003 caller-id enable ! voice-port 0/0/3 station-id number 4004 caller-id enable ! voice-port 0/1/0 trunk-group ALL_FXO 63 translation-profile incoming INCOMING_CallerID_PROFILE connection plar opx 3098 description Configured by CCA 4 FXO-0/1/0-AA-Custom-AA caller-id enable ! voice-port 0/1/1 trunk-group ALL_FXO 64 translation-profile incoming INCOMING_CallerID_PROFILE connection plar opx 3098 description Configured by CCA 4 FXO-0/1/1-AA-Custom-AA caller-id enable ! voice-port 0/1/2 translation-profile incoming INCOMING_CallerID_PROFILE connection plar opx 3098 description Configured by CCA 4 FXO-0/1/2-AA-Custom-AA caller-id enable ! voice-port 0/1/3 translation-profile incoming INCOMING_CallerID_PROFILE connection plar opx 3098 description Configured by CCA 4 FXO-0/1/3-AA-Custom-AA caller-id enable ! voice-port 0/4/0 auto-cut-through signal immediate input gain auto-control -15 description Music On Hold Port ! sccp local Loopback0 sccp ccm 10.1.1.1 identifier 1 version 3.1 sccp ! sccp ccm group 1 associate ccm 1 priority 1 ! dial-peer cor custom name internal name local name local-plus name international name national name national-plus name emergency name toll-free ! ! dial-peer cor list call-internal member internal ! dial-peer cor list call-local member local ! dial-peer cor list call-local-plus member local-plus ! dial-peer cor list call-national member national ! dial-peer cor list call-national-plus member national-plus ! dial-peer cor list call-international member international ! dial-peer cor list call-emergency member emergency ! dial-peer cor list call-toll-free member toll-free ! dial-peer cor list user-internal member internal member emergency ! dial-peer cor list user-local member internal member local member emergency member toll-free ! dial-peer cor list user-local-plus member internal member local member local-plus member emergency member toll-free ! dial-peer cor list user-national member internal member local member local-plus member national member emergency member toll-free ! dial-peer cor list user-national-plus member internal member local member local-plus member national member national-plus member emergency member toll-free ! dial-peer cor list user-international member internal member local member local-plus member international member national member national-plus member emergency member toll-free ! ! dial-peer voice 1 pots service stcapp port 0/0/0 ! dial-peer voice 2 pots service stcapp port 0/0/1 ! dial-peer voice 3 pots destination-pattern 4003 port 0/0/2 no sip-register ! dial-peer voice 4 pots destination-pattern 4004 port 0/0/3 no sip-register ! dial-peer voice 5 pots description ** MOH Port ** destination-pattern ABC port 0/4/0 no sip-register ! dial-peer voice 6 pots description catch all dial peer for BRI/PRI” translation-profile incoming nondialable incoming called-number .% direct-inward-dial ! dial-peer voice 50 pots description ** incoming dial peer ** incoming called-number ^AAAA$ port 0/1/0 ! dial-peer voice 51 pots description ** incoming dial peer ** incoming called-number ^AAAA$ port 0/1/1 ! dial-peer voice 52 pots description ** incoming dial peer ** incoming called-number ^AAAA$ port 0/1/2 ! dial-peer voice 53 pots description ** incoming dial peer ** incoming called-number ^AAAA$ port 0/1/3 ! dial-peer voice 54 pots description ** FXO pots dial-peer ** destination-pattern A0 port 0/1/0 no sip-register ! dial-peer voice 55 pots description ** FXO pots dial-peer ** destination-pattern A1 port 0/1/1 no sip-register ! dial-peer voice 56 pots description ** FXO pots dial-peer ** destination-pattern A2 port 0/1/2 no sip-register ! dial-peer voice 57 pots description ** FXO pots dial-peer ** destination-pattern A3 port 0/1/3 no sip-register ! dial-peer voice 2000 voip description ** cue voicemail pilot number ** translation-profile outgoing XFER_TO_VM_PROFILE destination-pattern 3099 b2bua session protocol sipv2 session target ipv4:10.1.10.1 voice-class sip outbound-proxy ipv4:10.1.10.1 dtmf-relay rtp-nte codec g711ulaw no vad ! dial-peer voice 2012 voip description ** cue prompt manager number ** translation-profile outgoing PSTN_CallForwarding destination-pattern 3097 b2bua session protocol sipv2 session target ipv4:10.1.10.1 voice-class sip outbound-proxy ipv4:10.1.10.1 dtmf-relay rtp-nte codec g711ulaw no vad ! dial-peer voice 58 pots trunkgroup ALL_FXO corlist outgoing call-emergency description **CCA*North American-7-Digit*Emergency** translation-profile outgoing OUTGOING_TRANSLATION_PROFILE preference 5 destination-pattern 9911 forward-digits all no sip-register ! dial-peer voice 59 pots trunkgroup ALL_FXO corlist outgoing call-emergency description **CCA*North American-7-Digit*Emergency** preference 5 destination-pattern 911 forward-digits all no sip-register ! dial-peer voice 60 pots trunkgroup ALL_FXO corlist outgoing call-local description **CCA*North American-7-Digit*7-Digit Local** translation-profile outgoing OUTGOING_TRANSLATION_PROFILE preference 5 destination-pattern 9[2-9]...... forward-digits all no sip-register ! dial-peer voice 61 pots trunkgroup ALL_FXO corlist outgoing call-local description **CCA*North American-7-Digit*Service Numbers** translation-profile outgoing OUTGOING_TRANSLATION_PROFILE preference 5 destination-pattern 9[2-9]11 forward-digits all no sip-register ! dial-peer voice 62 pots trunkgroup ALL_FXO corlist outgoing call-national description **CCA*North American-7-Digit*Long Distance** translation-profile outgoing OUTGOING_TRANSLATION_PROFILE preference 5 destination-pattern 91[2-9]..[2-9]...... forward-digits all no sip-register ! dial-peer voice 63 pots trunkgroup ALL_FXO corlist outgoing call-international description **CCA*North American-7-Digit*International** translation-profile outgoing OUTGOING_TRANSLATION_PROFILE preference 5 destination-pattern 9011T forward-digits all no sip-register ! dial-peer voice 64 pots trunkgroup ALL_FXO corlist outgoing call-toll-free description **CCA*North American-7-Digit*Toll-Free** translation-profile outgoing OUTGOING_TRANSLATION_PROFILE preference 5 destination-pattern 91800....... forward-digits all no sip-register ! dial-peer voice 65 pots trunkgroup ALL_FXO corlist outgoing call-toll-free description **CCA*North American-7-Digit*Toll-Free** translation-profile outgoing OUTGOING_TRANSLATION_PROFILE preference 5 destination-pattern 91888....... forward-digits all no sip-register ! dial-peer voice 66 pots trunkgroup ALL_FXO corlist outgoing call-toll-free description **CCA*North American-7-Digit*Toll-Free** translation-profile outgoing OUTGOING_TRANSLATION_PROFILE preference 5 destination-pattern 91877....... forward-digits all no sip-register ! dial-peer voice 67 pots trunkgroup ALL_FXO corlist outgoing call-toll-free description **CCA*North American-7-Digit*Toll-Free** translation-profile outgoing OUTGOING_TRANSLATION_PROFILE preference 5 destination-pattern 91866....... forward-digits all no sip-register ! dial-peer voice 68 pots trunkgroup ALL_FXO corlist outgoing call-toll-free description **CCA*North American-7-Digit*Toll-Free** translation-profile outgoing OUTGOING_TRANSLATION_PROFILE preference 5 destination-pattern 91855....... forward-digits all no sip-register ! dial-peer voice 2001 voip description ** cue auto attendant number ** translation-profile outgoing PSTN_CallForwarding destination-pattern 3098 b2bua session protocol sipv2 session target ipv4:10.1.10.1 voice-class sip outbound-proxy ipv4:10.1.10.1 dtmf-relay rtp-nte codec g711ulaw no vad ! ! no dial-peer outbound status-check pots ! ! telephony-service video fxo hook-flash max-ephones 40 max-dn 300 ip source-address 10.1.1.1 port 2000 auto assign 1 to 1 type bri calling-number initiator service phone videoCapability 1 service phone ehookenable 1 service phone backlightOnDuration 24:00 service dnis overlay service dnis dir-lookup service dss timeouts interdigit 5 system message Morrow Road | 585.484.7156 url services http://10.1.10.1/voiceview/common/login.do url authentication http://10.1.10.1/voiceview/authentication/authenticate.do cnf-file perphone load 7942 SCCP42.8-5-4S load 7945 SCCP45.8-5-4S load 7962 SCCP42.8-5-4S load 7965 SCCP45.8-5-4S load 521G-524G cp524g-8-1-17 time-zone 12 keepalive 30 auxiliary 4 voicemail 3099 max-conferences 8 gain -6 call-forward pattern .T call-forward system redirecting-expanded moh flash:/media/music-on-hold.au multicast moh 239.10.16.16 port 2000 web admin system name cisco secret 5 $1$6Bj6$Zk6BJ/Id6NjhIApWdk4lO1 dn-webedit time-webedit transfer-system full-consult dss transfer-pattern 9.T transfer-pattern .T transfer-pattern 6.... blind secondary-dialtone 9 night-service day Sun 17:00 09:00 night-service day Mon 17:00 09:00 night-service day Tue 17:00 09:00 night-service day Wed 17:00 09:00 night-service day Thu 17:00 09:00 night-service day Fri 17:00 09:00 night-service day Sat 17:00 09:00 fac standard create cnf-files version-stamp 7960 Nov 24 2017 00:39:07 ! ! ephone-template 1 url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress service phone webAccess 0 softkeys remote-in-use Newcall softkeys hold Resume Newcall softkeys idle Redial Dnd Cfwdall Pickup Gpickup Login softkeys seized CWOff Callback Cfwdall Endcall Redial Pickup Gpickup softkeys connected Flash Hold Park Trnsfer TrnsfVM Confrn button-layout 7931 2 ! ! ephone-template 15 url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress softkeys remote-in-use Newcall softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Acct Park button-layout 7931 2 ! ! ephone-template 16 url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress softkeys remote-in-use Newcall softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Acct Park ! ! ephone-template 17 url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress softkeys remote-in-use CBarge Newcall softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Acct Park ! ! ephone-template 18 url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress softkeys remote-in-use CBarge Newcall softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Acct Park button-layout 7931 2 ! ! ephone-dn 1 number 1001 no-reg primary description IP-Paging1 name Announcement paging ip 239.1.1.1 port 2000 ! ! ephone-dn 9 number BCD no-reg primary description MoH moh out-call ABC ! ! ephone-dn 283 number 4400 no-reg primary park-slot timeout 120 limit 2 transfer 2004 retry 120 limit 2 label Parking lot A ! ! ephone-dn 284 dual-line number 2008 no-reg primary pickup-group 1 label 2008 description General Extension 2008 name General Extension call-forward busy 3099 call-forward noan 3099 timeout 20 ! ! ephone-dn 285 dual-line number 2007 no-reg primary pickup-group 1 label 2007 description Extension 2007 name General Extension call-forward busy 3099 call-forward noan 3099 timeout 20 hold-alert 15 shared ! ! ephone-dn 286 octo-line number 3308 no-reg primary label Trading Post 3308 description Trading Post 3308 name Trading Post call-forward busy 3099 call-forward noan 3099 timeout 20 ! ! ephone-dn 287 octo-line number 3307 no-reg primary label Pass-N-Thru 3307 description Pass-N-Thru 3307 name PassN Thru call-forward busy 3099 call-forward noan 3099 timeout 20 ! ! ephone-dn 288 octo-line number 3306 no-reg primary label Dunkin 3306 description Dunkin 3306 name Dunkin Donuts call-forward busy 3099 call-forward noan 3099 timeout 20 ! ! ephone-dn 289 octo-line number 3305 no-reg primary label Bev 3305 description Bev 3305 name Beverly Popp call-forward busy 3099 call-forward noan 3099 timeout 20 ! ! ephone-dn 290 octo-line number 3302 no-reg primary label Jim 3302 description Jim 3302 name James Jerris call-forward busy 3099 call-forward noan 3099 timeout 20 ! ! ephone-dn 291 octo-line number 3301 no-reg primary label Nate 3001 description Nate 3001 name Nathan Draco call-forward busy 3099 call-forward noan 3099 timeout 20 ! ! ephone-dn 292 dual-line number 2006 no-reg primary pickup-group 1 label Shed 2006 description Shed 2006 name Shed Shed call-forward busy 3099 call-forward noan 3099 timeout 20 hold-alert 15 originator ! ! ephone-dn 293 dual-line number 2005 no-reg primary pickup-group 1 label Kitchen 2005 description Kitchen 2005 name Kitchen Kitchen call-forward busy 3099 call-forward noan 3099 timeout 20 hold-alert 15 originator ! ! ephone-dn 294 dual-line number 2004 no-reg primary pickup-group 1 label Living 2004 description Living 2004 name Living Living call-forward busy 3099 call-forward noan 3099 timeout 20 hold-alert 15 originator ! ! ephone-dn 295 dual-line number 2003 no-reg primary pickup-group 1 label Office 2003 description Office 2003 name Office Office call-forward busy 3099 call-forward noan 3099 timeout 20 hold-alert 15 originator ! ! ephone-dn 296 dual-line number 2002 no-reg primary pickup-group 1 label Keefer 2002 description Keith 2002 name Keith Kress call-forward busy 3099 call-forward noan 3099 timeout 20 hold-alert 15 originator ! ! ephone-dn 297 dual-line number 2001 no-reg primary pickup-group 1 label Melinda 2001 description Melinda 2001 name Melinda Reynolds call-forward busy 3099 call-forward noan 3099 timeout 20 hold-alert 15 originator ! ! ephone-dn 298 number 6.... no-reg primary description ***CCA XFER TO VM EXTENSION*** call-forward all 3099 ! ! ephone-dn 299 number A801.... no-reg primary mwi off ! ! ephone-dn 300 number A800.... no-reg primary mwi on ! ! ephone 1 device-security-mode none mac-address 0019.30D5.163E ephone-template 1 username "MReynolds" password whiterain speed-dial 1 1001 label "Page - Group 12" paging-dn 1 type 7961 button 1:297 2m296 3m295 4m294 button 5m293 ! ! ! ephone 2 device-security-mode none mac-address 0019.30D4.C2AE ephone-template 1 username "KKress" password whiterain speed-dial 1 1001 label "Page - Group 12" paging-dn 1 type 7961 button 1:296 2m297 3m295 4m294 button 5m293 ! ! ! ephone 3 device-security-mode none mac-address 0022.9005.7E1B ephone-template 1 username "OOffice" password whiterain speed-dial 1 1001 label "Page - Group 12" paging-dn 1 type 7961 button 1:295 2m297 3m296 4m294 button 5m293 ! ! ! ephone 4 device-security-mode none mac-address 001B.535D.55A0 ephone-template 1 username "LLiving" password whiterain speed-dial 1 1001 label "Page - Group 12" paging-dn 1 type 7970 button 1:294 2m297 3m296 4m295 button 5m293 6w292 ! ! ! ephone 5 device-security-mode none mac-address 000D.BDBF.1665 ephone-template 1 username "SShed" password whiterain paging-dn 1 type 7960 button 1:292 2m297 3m296 4m295 button 5m294 6m293 ! ! ! ephone 6 device-security-mode none mac-address 0024.C455.3468 ephone-template 16 max-calls-per-button 4 username "KKitchen" password whiterain speed-dial 1 1001 label "Page - Group 12" paging-dn 1 unicast type 7921 button 1:293 2m297 3m296 4m295 button 5m294 ! ! ! ephone 7 device-security-mode none mac-address 413A.E8A2.0001 ephone-template 16 max-calls-per-button 2 username "G.2007" password whiterain type anl button 1:285 ! ! ! ephone 8 device-security-mode none mac-address 413A.E8A2.0000 ephone-template 16 max-calls-per-button 2 username "G.2008" password whiterain type anl button 1:284 ! ! alias exec cca_voice_mode PBX banner login ^Cbanner login ^Cisco Configuration Assistant. Version: 3.2 (3). Sun Nov 12 22:12:58 EST 2017^^C ! line con 0 no modem enable line aux 0 line 2 no activation-character no exec transport preferred none transport input all line vty 0 4 transport preferred none transport input all line vty 5 100 transport preferred none transport input all ! ntp master end
12-20-2017 01:59 AM
Try isolate you UC540 and leave only one workstation on it and make the speed test again.
You may also want to disable inspection for this test:
interface FastEthernet0/0 no ip inspect SDM_LOW out
12-22-2017 10:25 AM
Thank you for your reply, so sorry for late response. I tried your command and now i have no WAN connectivity on any of the ports
12-22-2017 03:58 PM
How to i remove that to at least get connectivity back?
