I am trying to figure out what products would I cluster with the 541N. I am not seeing an explicit recommendation. I would like to make the decision before purchasing. Any help would be appreciated.
Thank you in advance.
Solved! Go to Solution.
Good stuff Steve! That guide is a must-have for anyone deploying voice.
To answer the question of the clustering ... the AP541 will only cluster with other AP541s.
If you need any more guidance or have questions about your design and product choices, do please respond and let us know. Have a great night,
Andrew Lissitz
Andrew Lissitz
Thanks guys. I actually found the answer by reading Steve's guide. Order 2 541N's can't wait until they arrive. Booyah!
Yep, that guide is pretty good. Be sure to check back occasionally as we update the guide with new products, capabilities, features, etc ...
Have a great night,
Andrew Lissitz
