Get
the latest new and information the November issue of the Cisco
Small
Business Monthly Newsletter
I know Airplay isn't meant to be done across vlans, but surely it should work with things on the same vlan.
The 541N's are clustered and have WDS enabled. The wireless VAP's are on the same VLAN, and intervlan routing works.
Airplay works if the iDevice and the Apple TV are connected to the same access point, but not across the network.
Any thoughts?
I found the solution.
Clustering and WDS have no affect on this. However, when I turned WDS on, it caused ports to flap and flood my network with packets and slowed everything down. So I turned it off. WDS will be my next step.
This is for 541N's that are only broadcasting ONE SSID.
On the 541N, the ssid MUST be on the same vlan as the Apple TV. The UNTAGGED vlan MUST be the same vlan as your Apple TV.
For 541N's that are broadcasting TWO SSID's on DIFFERENT VLANS, the untagged vlans MUST BE DISABLED.
FOR 541N'S BROADCASTING ONE SSID
The 541N has an address of 10.0.2.3/24 on vlan 20.541N with one SSID Config:
541N with one SSID Wireless Config:
THE SWITCH MUST BE CONFIGURED AS FOLLOWS! (This is a 2960WS switch):
switchport trunk native vlan 20
switchport trunk allowed vlan 20
switchport mode trunk
FOR 541N'S BROADCASTING MULTIPLE SSID's
The 541N has an address of 10.0.2.5/24 on vlan 20541n Broadcasting multiple SSID Config:541N with multiple SSID'sTHE SWITCH MUST BE CONFIGURED AS FOLLOWS! (This is a 2960WS switch):
switchport trunk allowed vlan 20,40
If you configure all your 541N's like this you will be able to airplay from any access point to any Apple TV.
