Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
2064
gjr
Beginner
Beginner
AP 541N Can't select UK for wireless
Hi all,
I have just installed a AP541N-K9-1.9(1) access point at my office.
I bought it new in the UK from a major retailer.
Under wireless settings > country selection, there is no UK option. I have upgraded the firmware to v1.9.1 but there is still no UK option.
Can anyone help me with which country to select please ?
15 REPLIES 15
gjr
Beginner
Beginner
Anyone ?
     I'm in the same situation. Same AP, Same firmware, no option for the UK.
wierd.
Alun.
I'm using Germany at the moment and it seems to work OK but having spent this much on an access point I would like to have it 100% right .
BUMP
Any one here from Cisco got any idea ?
tgronek
Beginner
What countries does it list?
Austria
Germany
Belgium
Denmark
Finland
France
Greece
Hungary
Ireland
Iceland
Italy
streaves
Learned from engineering today that this is on the road map. Can't give you a firm date but please stay tuned and thanks for bringing it to our attention.
Stephanie Reaves
Small Business Technology Group
Thank you very much!
In the meantime which country should I set to 'match' the UK ?
streaves
Recommend you select Ireland for now. The next firmware release will include UK as an option.
You also have  the option to simply disable 802.11d.
Stephanie
Thanks!
streaves
Thank you very much for the heads up Stephanie but it still doesn't have UK in the list !!!
Out of interest do you know what it does change ?
Kind regards
graham
streaves
Hi Graham -- Fear I posted the announcement without digging deep enough. The "UK" is slated for 2.0 firmware release, which is still in the works. The Release Notes for yesterday's 1.9.2 release can be accessed here: http://www.cisco.com/en/US/docs/wireless/access_point/csbap/AP541N/release_notes/78-19182.pdf.
Apologies for the confusion.
Stephanie
OK, well thanks for the update anyway :-)
