AP541 - wireless client can't ping wireless client
phcjpp123
Hi Guys,
I have a setup involving 3 clustered AP541 running off a sg300 switch. The wireless network setup VAP has one entry for vlan 1 with station isolation disabled. Is there anything more I need to do to allow one wireless client to ping another wireless client - am I missing something - i assume this is possible.
Needless to say wireless clients can ping non wireless clients and vice versa quite happily. Everything is running with factory default settings more or less.
Chris
mpyhala
Level 7
Level 7
Hi Chris,
Edit: I noticed that you already checked the Isolation setting. Does the AP have the latest firmware?
Message was edited by: Martin Pyhala
I believe so yes - AP541N-K9-2.0(0)
Cheers
Chris
Just checked and upgraded to 2.01 - i can now ping - lets hope it remembers it as in the past it has seemed to forget the setting.
Chris
Chris,
Thanks for the update. Please let us know if anything changes.
