AP541N cluster and VLAN
bastardz12
Hi.
Simple but not obvious question.
I've added separated wifi for guest with VLAN ID 300. Now I have 2 more access points. They are in cluster but only one is connected to smart switch SLM2008.
Should I need to connect all of them to smart switch? I do not understand how cluster and VLAN work.
vvijaysa
Hello Tomasz,
Yes. I guess you need to connect all APs to the switch (same bridged network). Clustering only makes all your AP act as one single entity ( you don't have to connect to the second AP In a cluster separately. Same wireless configuration will do).
Refer Clustering section under the below manual for further details:
http://www.cisco.com/en/US/docs/wireless/access_point/csbap/AP541N/administration/guide/AP541Nadmin.pdf#page139
Hope this helps,
Vijay
Please rate useful posts.
