04-18-2013 12:21 PM
Hello guys,
I've little problem with my access point so, this is my little network :
On this PC, I haven't visio, so i create my lab with PKT =)
After this the DHCP request failed :/
Thanks fur ur help.
Solved! Go to Solution.
04-22-2013 04:47 PM
Hi Emmanuel
Could you share with us your router configuration, it looks like you are having problem with the "Router-on-a-stick", is this a real scenario or are you just practicing?
“Please rate useful posts so other users can benefit from it”
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
04-22-2013 04:47 PM
Hi Emmanuel
Greetings,
04-23-2013 12:35 AM
Thanks for ur answer,
But i found my problem, a simple reboot of the AP has sufficient
Mystery
It's just for practise
