ap541n how many clients, how many MAc addresses in the filter list
Hi All,
I've few question about AP541N:
what is the max. number of clients simultanousley connected to AP541N?
what is the max. number of entries in MAC filter list on the AP?
what is the real throughput of this AP in 802.11n mode?
Thanks!
Lukasz
5 Replies 5
Martin Mc Court
I too would like anwers to the above please.
Martin.
Most of your questions can be found in the AP541 Data Sheet:
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10492/data_sheet_c78-566239.html
Rick Roe
Cisco Small Business Support Center
Thanks Rick, I've had a look at the data sheet, however, it does not specify how manay simultaneous users are supported on the AP541.
Can you advise?
Martin.
Hi Martin!!
If you take a look to "Advanced Settings", option "Wireless" in Access Point Configuration Utility, you can setup the feature "Maximum Stations" from 0 to 200, I think that it's the same that max clients and max mac address.
Good luck!!
Gabriel
I need to know the answer to this question too.
