AP541N with WDS and Clustering
John Gawf
I have two AP541's, one which can be cabled to the LAN.  The second one will not be on a LAN and I've enabled WDS and Clustering.  Will I be able to take advantage of the Clustering capabilities in this topology?  Will I be able to mange the second box using its LAN IP address even though access to it will be across the WDS bridge?
Glenn Quesenberry
Yes, you should have no trouble clustering that AP and reaching it over the Wireless LAN.  You will need to connect it via a cable initially to set it up however.
Best Regards,
