Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
From the moment the device is pluggedd the power led trun solid green, and can't access via GUI and not spread WiFI siganl. is there another metod to load a new firmware image?
Hello, I have a cicso 145ac and I dont understand why it can read my sv jung servers ip adress but not my schneider knx ip router somehow. are there any more things to do.I wanted to use this as some kind of switch to reduce cabelingWhen the schneid...
Hello,I noticed today that probably after a firmware update ( to 1.3.0.7) in the cluster of three WAP371, one WAP created a second cluster with the same name. The firmware update did not work for this WAP either.I made up for the firmware update, but...
Dear Community Iam kind of annoied right now. For the last 10 years it was easy for me to setup Cisco APs for customers.The setup was always the same. Two VLans Routed on the Router with DHCP enabled on the Router, a trunk to the Accesspoint, two SSI...
Question is in the title, but can the subordinate AP reach out and connect to the AP controller wireless or does it demand that it has to connect over LAN connection?
For the life of me, I cannot figure this out so request some help.I would like wireless users associating to SSID-A on my CBW140AC to be connected to VLAN50 and be sent out to internet via interface outside just like every other LAN connected clients...
Please be advised, the automated software distribution services will no longer be available from March 1st (2022) forward. The following devices are affected:
RV260/RV160 seriesRV34x seriesCisco Business Wireless (CBW) access points
There is a simple...
I assume it happens after kernel: [41820.446622] wl0: fatal error, reinitializing kernel: [41820.446607] wl0: Fatal error: Big hammer due to increasing rxanyerror kernel: [41820.384108] br-vlan1: received packet on wl0 with own address as source addr...
Having issues updating my software. Unable to do this on mobile app and also on online portal via HTTP. Error: ImageReq to AP FailedRetry attempts +15 Logging:*spamReceiveTask: Feb 16 13:55:21.195: %APF-3-MESH_EXTENDER_AUTHORIZED: spam_radius.c:288 W...
HI all. When I am turning connecting up a new CWB240AC onto the network, the mac address is automatically being added to the allowed MAC list. I am not adding it myself. How do I stop this? AP's should not join unless I have added the MAC address...
I have CBW 240 AC Access point and it shows me operational status is down It was working earlier I just increased the 5GHz channel width from 20 to 40 but I reverted back. Still I am unable to see the SSID. Any help?
This has been an ongoing struggle with the WAP-150 since I installed them. I have 2 units with a single-point setup. The 5 GHz disappears and the 2.4GHz has connected the clients, but the client has no LAN or Internet connection. Seems to happen...
Hi, I have a set of cbw240ac access points that I have been trying to get working in a mesh setup. I'm not using extenders but rather multiple cbw240ac units. However I can only get them working when cabled together, do they not support mesh thems...
I have two AP's CBW145AC and I need to connect them to each other wired, with the primary supplying data and power wired to the second, which is in another room. After installation and configuration, the second ap does not appear on the network and o...
