Small Business Wireless
Helpful support links - emulator, video tutorials, support pages +
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
CoreyP319 by Cisco Employee
  • 1128 Views
  • 1 replies
  • 5 Helpful votes
Wireless disconnects
Hi GuysI am at my wits end here with my wireless implementation and hoping somebody can help.I have 8 WRVS4400N Wireless-N routers set up on different channels using the same SSID and WPA2 enterprise authentication for roaming. Everything seems to co...
Genome_666 by Beginner
  • 1777 Views
  • 3 replies
Detailed syslog from WAP4410n
HiI need to count traffic used by each device connected to the access point.The manual says: In addition to the standard event log, the access point can send adetailed log to an external Syslog server. The access point’s Syslogcaptures all log activi...
lastochka by Beginner
  • 1351 Views
  • 6 replies
Mysterious wireless disconnects
                   At a local library I have a Cisco/Linksys RVS4000 router doing all the DHCP assignment. Attached to it are 2 WAP200 wireless access points at opposite ends of the building. The WAPs provide all the public internet access. All staff...
bradleybay by Beginner
  • 1062 Views
  • 1 replies
Resolved! AP541N drops all clients
As I posted about in the other AP541N thread about degraded performance, mine did a strange client disconnect last week. It dropped all authenticated clients, but they all thought they were still connected. A quick disable/enable of the wireless card...
Best range .11n AP/Antenna
Hi all,with help of great people in this forum I understand that seamless wireless roaming with multiple APs is not posssible without a wireless lan controller.That's overkill for me, hence the following question: what is the highest signal strength ...
Henri0001 by Beginner
  • 964 Views
  • 1 replies
Client problems with AP541N
Hello,I have problems with a newly installed AP541N wireless network, seems that I'm not the only one, but the threads I have been looking at doesn't seem to have exctly the same problemClients:Windows XP, Windows 7 and Apple OSX client computers. (i...
welln by Beginner
  • 1648 Views
  • 1 replies
RVS4000 VPN Dropping
I installed a RVS4000 at a remote location a few days ago.  Traffic is flowing fine over it 90% of the time however for some reason traffic will just stop.  You are unable to ping the other side from either site.  The summary shows the VPN is up.  Th...
