Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Does anybody know if the WAP321 is any good? Do they have the dropping connections problem that the WAP4410n's do.I can't afford to buy another lemon.Thanks,chad
I was looking for some clarification on the capabilities of these devices to allow roaming of clients between AP's. Take a basic scenario of 3 AP's and a single SSID. I know the AP541N has clustering which uses the Fast Client Roaming Protocol, whi...
We are on our 2nd 4410N. we monitor the AP with software that graphs the signal strength. the first 4410N would completely dissappear for about 3 to 5 seconds every few hours, that would disconnect users and annoy them greatly. a ...
I would like to connect the AP541N to the RV220W and use the same SSID assigned to both throughout the office, for seemless client movement. I would like to keep the AP541N connected via the internet cable, as it will be on a switch which is on the ...
I have the strangest issue I can't figure out. Two, and there are only two, client endpoints sharing the WAP4410N AP have unreliably connection between them... "through" the AP. Isolation disabled, of course. Ping between client(s) and AP, both ways,...
Hi all,I 've bought an AP541N & WAP4410N for the purpose to wireless(ly) bridge my TV with the Internet.The AP541N is connected to a AS5505 > Internet.My TV is connected to the ethernet port of the WAP4410N. (Also tried my laptop)I 've set WDS bridgi...
Hello, I would like for someone to provide personal service by phone/modem related to various questions that I have regarding my six AP541 access points.All six are "clustered" however I want to discuss WDS, a guest account, and QOS.I might also want...
We've got an SA520W that's performing nicely, but we need to extend our wireless coverage to a new area of the building (we can get a network cable there). What would be our best option? Just a second SA520W, or are there are APs we should look at?...
I am using WRVS4400N in our company as a AP only.Before some time, when majority of wireless clients were computers, everything worked fine. But now, when mobile devices are in majority, something strange is happening.While portable computers still w...
Hi,I have to connect some roaming PCs, but using the cable to a wireless network with AP541, I was looking for an entry-level indoor AP that can operate by way of CPE ie client. What could I use among the products in the Cisco portfolio?NB: Today is ...
I am trying to setup the above environment. When I connect on my guest network it does not give me an IP address from my guest network DHCP scope that is configured on my CISCO router.Does anyone have any idea how to set this up??...
I just got one of these and it works pretty good except I can't get it to take more than a 32 character WPA2 PSK. Tried using Firefox and IE and it doesn't make a difference. This is for my house. I'm retiring an old Cisco 1200 series AP and as we...
Hi at all,we would like to use an WRVS4400N to create multiple ssids to seperate the lan users from the guest users.We want to use the WRVS4400N just as Access Point not for router or firewall purposes. So we configured two ssids. the first for the l...
I have a client that requires a single router with POE for placement at an economical price. I was considering the Linksys WAPPOE12, but that is discontinued. What would work with that router?
Okay, things are moving along with my wireless environment but I am now looking for more help.As we move from autonomous APs to our LWAPPs I would like to make this process as seemless as possible. I see that I can configure LDAP for authentication. ...
