Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I have Cisco AP4410N access point in my network and want to configure MAC Address Filtering but the said AP support only 20MAC to configure on the Database of the AP. Please advice is any other way for the support of more MAC Address config...
Hi,I do have problems with remote management of a Wireless Accespoint WAP200.The WAP200 is connected to a router RVS4000 and works well.There are several nodes in the LAN, all static IP, all forwarded in the RVS4000.All nodes can be managed in the LA...
Hello,We have about 20 of the above WAPs in our company network and are quite satisfied with the performance.However occasionally we need to manually reboot the WAPs in order to resolve sporadic connectivity issues that cannot be resolved on the clie...
Hello everybody.Not long ago i was bought Cisco wap2000 access point for small business, and now the problem is to find power injector for this device.I am already tried to use AIR-PWRINJ3, but access point did't turn on. Why?Which power injector sho...
I had to set up security connected directly to laptop but when I connect the WAP4410N to the domain network I can not access it using http://192.168.1.245 . What can I do to access this box before I put in its final location, on top of the office. is...
I have an AP541N-A-K9. For the past couple weeks it stops work at 5:00pm. The clients can see the SSID but when they connect it fails. The only way to get this to work again, is to set the radio to 5GHz 802.11N. Setting the radio to anything else ...
I have 4 pcs on my WAP. 3 are Win 7, one is Win XP.None of these PC's can see each other to create a Homegroup.After spending several hours with tech support with ESET (security s/w), we determined the following:My WAP4410N is wired to my router. T...
Hi,I want to split the usage of the AP so that visitors are on their own wireless connnection and VLAN.We have 2 WAP4410N APs. One AP acts as a repeater for the another AP.They are both in 4.0.4.2 firmware.We are using WPA2 RADIUS authentication, an...
I have three Cisco WAP4410N access points. I'm trying to use VLANS, one untagged and the other three tagged. I don't see how to configure each SSID for VLAN tagging using the web interface. Is it possible to have both tagged and untagged VLANS and ...
HI,I have a small business, i use to have an Access Point from another brand, I had a lot of problems using it like every time it looks like it freeze, I can see the wireless but I don’t get internet access from it, and I need to reboot it to fix thi...
Hello,I've set a WAP4410N to the "Wireless Client/Repeater" mode so that I can use it as a client to connect to another access point through WPA2-PSK. The problem is that it does not associate with the target WLAN.Debugging the issue via SSH I notice...
Hi,I plan to extend the wireless signal for RV220W as a wireless access points now.Please kindly suggest which model is suitable.Can we use lower end model instead of another RV220W?Thank you.
Hai everybody....How can i download the webauth bundle(web Authentication Page) in Wireless Lan controller ,as i am going to replace with New Wireless LAN controller.
Hi!I own two WAP4410N-E V02 Access Points and I am (too) experiencing loads of problems even after upgrading both to the BETA Software Version 2.0.5.2As most other users keep reporting, the router, for no apparent reason, will stop allowing connectio...
Hello All,First time I request something, but it seems a good place to start from.I have a WRVS4400n and a SG300-28. I have successfully created 3 Vlans on the router and on the switch but I am missing a link as the DHCP created on the router will no...
