Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
HiWe have an installation where we have a number of WAP200's running via POE from SF200-48P switches. The wireless range is not good. If we connect the WAP to a non POE port and use an external POE injector the range improves (maybe doubles).Can anyo...
How Can i Connect wireless router wrt45g2 wirelessly to access point wap4410n ??I have tried but its not able to get through with the settings. Please let me know the configurations
I am moving to a house in a fairly remote part of Australia without a telephone connection. To get the phone connected will be very expensive and take considerable time. I have mobile phone and wireless internet connection available but only with the...
I have a wrv210 positioned at the end of a 4 building shopping center, in a room that is farthest away from our phone system. There is a chance that the phones operate in the 2.4 ghz frequency. My question is, could the phones cause wireless comput...
Hello is the first time i have cisco I can't do hardware reset in wap 200e I try as the manual said but nothing When i connected with lan said there is no lan in my pc in order to acces the ip.Please any suggestionsThanks a lot
Greeting AllWe have two wireless SSID: One Corporate and one SSID for guestThe wireless corporate has an SVI X that exist on the core network and the guest is only layer 2 that connects to a firewall which provides the DHCP serviceThe issue that we h...
We have a few of these routers at different locations. Notice at a couple locations, when we login to router, the left side seems to look ok. When you click on for example "basic setup", the right side is all white and you have to scroll down a pag...
We have a cisco network with 2 Cisco AP 541N access points in different locations. The network looks (roughly) as follows:Both access points are joined into a cluster. They only transmit VLAN 10. Neither Are using PoE but both are capable of it.AP2 s...
I am working with a client to build upon existing wireless infrastructure. I am advised of the S/N ( GKS143800LM ) but told model identification is not visible. The unit is mounted in a hard to reach location. Is there a way to get to the model of...
Hi,I am looking for an access-point or a router that has DHCP-client enabled on its Wireless side. Imagine all computers/devices are wired and don't support wireless. Here is a diagram:Service Provider----)))))))) Wi-Fi/802.11a/b/g/n (((((((((((((--...
Hi,I have recently upgraded my Cable modem from Singapore Service Provider, Starhub. It is using Cisco DPC3925 cable modem. The modem has been setup successfully in my home. However, I face the following problems.The modem will disconnect and reset a...
WRVS4400N with firmware version V2.0.0.8.After about an hour it routinely drops wireless clients. Wired clients are fine.Re initiating a connection from the clients usually restores the connection fine. Sometimes this is just doing something to for...
I need some help setting up QoS for two Cisco/Linksys devivces on my network. Network devices are Comcast SB6120 modem into WRVS4400n (v2.0.2.1 firmware) that divides into one 24 port gigabit Netgear unmanaged switch, 1 port into AT&T Cisco Microcel...
All of my remote sites use various routers to route all of their traffic via IPsec. However, I have one WRVS4400N w/firmware 2.0.2.1 configured with a working tunnel. My issue is I need to set the Remote Group to 0.0.0.0 0.0.0.0 so all traffic is f...
(Sorry for my English)Hello,I buy a WRVS4400N router on amazon.fr because on cisco.com, the Product Specifications say "Dual-stack IPv4 and IPv6" http://www.cisco.com/en/US/prod/collateral/routers/ps9923/ps9931/data_sheet_c78-496737.htmlThe ipv6 work...
