Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello,I have a big house and I had bought the equipments:Router netgear3 Access Points - wap4400nSomeone They told me that I could use the same network name as follows:2nd floor,set the Access Point (default)On the first and third floor set the Acces...
I have seen posts and screen shots of WRVS4400N settings screens showing WDS but I can't find anywhere in my setup to enable WDS on my version 1. I am running firmware 1.1.13. This makes me think WDS is only supported on v2 of the WRVS4400N, is that ...
Hi,I have recently tried to install three 4410N's...one as an AP with the box ticked that says "Allow wireless signal to be repeated" and the other two as "Wireless Client Repeaters" with the "allow wireless station to associate" box ticked. I've als...
Our wireless clients that connect through our AP541N cannot see other computers on the network. They can ping other computers by IP and host name and access the internet OK. Mapped network drives can be connected initially but are very unreliable a...
I have had a WRV200 wireless router running at the family office now for a several years now and recently I was made aware of an issue with the router. Previously it's function was to provide internet access for the laptops at the office and two work...
We are trying to setup a wireless system at our restaurant to be able to use wireless handheld POS devices and allow guest internet access. The hardware we have is, RV 120W Router, and 2 WAP200 access points. What we were trying to do is setup a VLAN...
I ordered a pair of WAP4410N to use as a bridge for a split office. So far they have worked without a hitch but the throughput is less than stellar and I was wondering what the recommended configuration was for best performance (and how much speed co...
HI,we have 4 access points in my network i want configure 1 is ap mode another 3 is bridge mode Is it possible to configure in 4410 N ?if i configure bridge mode can i use single SSID&Securtiy key for all aps. plz give me a best solutions. how to i u...
Hello can i use Wireless-G Internet home monitoring for other cams except WVC54GCA because i have 3 of them and one foscam.. and i want to use that software.. is possible?
I just purchased a WRVS4400N with the intention of giving myself a secure way to remotely access my local network from anywhere via VPN. I created a local VPN account and had a friend install the QuickVPN client on his system. He gets connected (I ca...
If WPA-PSK TKIP or AES encryption is enabled, my Spectec SDW-821 SDIO wlan card can not connect to the WAP4410N (h/w "WAP4410N-E V02", f/w 2.0.2.1). If security is off or set to WEP 128 bits (thanks to Cisco's support), connection succeedsThe card wo...
Hi ! I bought a new WAP4410n a few weeks ago. Since then, I had tried different ways of configutarion to make that WAP4410n works as a repeater to my WRVS4400n v2. Both are running the lastest firmware available by cisco. I made the WAP4410n a mirror...
Recently bought a 892W security router.In setting up it I get the empty screen with only an enter button (offceextend ap)Now I saw a solution to this problem for the 891W somewhere in these pages however I can not download the appropriate software si...
hi,i set up the WAP4410N and it can be connected with our router. But it's not protected by our password, but once i have set the password of WAP4410N by changing the security mode to WEP, now i will prompted to password when I connect the AP, but it...
Hi,Recently I have purchased two brand new wap4410n access points. I have connected my computer directly to one of the access points, and attempted to connect to the Web Configuration utility through my web browser.I'm using a: 09' MacBook Pro, runni...
