Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi, i setup the CBW140 Business Mesh Starter Kit in my Restaurant. This all works fine. But unfortunately i have one room which is not covered in the moment.I thought about adding another wired CBW140 Access point which shall be able to work independ...
Greetings,I'm new to the community so please forgive me if this is the wrong forum to post this question. I recently installed a CBW140AC Starter Kit (1 AP and 2 Mesh Extenders). After configuring the mesh extenders (via the Web UI by visiting cisc...
I don't see anything in the specs about the Wireless Mesh Extender USB power supplies. Is this a power module with a separate USB Cable? What is the length of the cable? What are the connectors on the cable in case I need a longer cable?
I have a question on the Starter Kit CBW140 with one Access Point (CBW140AC-E Business Access Point) and two 142ACM Mesh Extender. If i would buy two of the Starter Kits. How would the APs work together ? And which of the devices would take the cont...
Hello there, I'm having issues accessing out WAP581 wireless devices. Wireless stopped working on the weekend and today we had to do a restart. After the restart I can see the devices using FindIT, the IP is on our network, but when I try to access t...
I am wondering why an AC140 which I know to be good is not powering up on a known good POE port of a CBS250 24 PP switch. Any ideas? I have plugged and unplugged the AC 140 multiple times. I have tested the cat5 cable and it passes. Thank you, J
HiWe have purchased 12 WAP571's (three orders) and set up a cluster. 5 AP's don't show a wireless channel for the 2.4 GHz (Monitor --> Single Point Setup Status). If 5 GHz is offline I can connect to 2.4 GHz anyway. Is this a firmware bug? We're stil...
I just installed a RV260P Router with a 240AC AP in mesh mode with 141 Mesh extender. I have setup the router with 4 VLANs (#1 left as default).I have set up the AP with 4 WLAN/SSID each mapped to a VLAN. I have left the port on the router for the AP...
Hello,I am encountering a weird problem with the buit-in guest captive portal on a WAP150 configured in single AP mode with the latest firmware (1.1.1.0).Actually the captive portal is only working as expected when the gest WLAN is located on the def...
Hi ! I can't solve this problems. Help me. This page shows on every web browsers. (Chrome, Fire fox, IE, Edge) I've checked browser are newest version. This is MGMT Web ui page, Every buttons are don't work.
HiAnybody knows how to configure a WAP 581? (the cisco support doesn't...)I simply want to connect a device on the wifi (5 or 2,4) and have an ip address given to the device.I can connect but i have no IP. How to activate DHCP and choose the class of...
hello can i use this device to setup a point-to-point connection. i mean make one of the AP a client Radio station? or it just an AP outdoor that can not perform the work of a Client Radio Station. i will like to get guide on how to configure if it i...
Hi, I'm trying to import an SSL certificate (pem file) to allow HTTPS inspection on my WAP121.When I try to upload using http upload I get the message "The certificate file failed to be uploaded".I could successfully upload that certificate on a MR33...
Hi I have recently purchased and set up 3 x WAP571's in cluster, on the bench all works ok however when deployed on site there are massive issues with signal strength for the 5Ghz range where as if we connect to the 2.4Ghz same WAP excellent signal q...
I want to create a cluster with 2 Access Points.
I can create a Cluster on the first AP. When i join the second AP to the cluster i have some strange problems:
- Under "Single Point Setup\Access Points" is only one Access Point listet (Only the AP...
