Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi,I have a WAP4410N access point. In the datasheet, it shows that the Antenna Gain in dBi as 2. I need to increase the range of the access point by replacing the antenna with a 7dB one. I would like to know the maximum dBi supported by this access p...
Can the Cisco WAP4410N Wireless-N Access Point: PoE/Advanced Security Cisco Small Business Access Point use the Cisco Aironet Power Injector (AIR-PWRINJ4)?I know there was a Linksys Business Power Injector, but that was gone with the Cisco take over....
Hi, We have a wireless-g access point typically (and previously, in this case) used for a small business. We were given the device for free and wanted to reset the device to use as our wireless router at home. First and foremost, can a wireless acces...
i would like to know if wap200e will still have connection if there are trees in between. because we have 2 offices that is 200 meters apart and trees all over them. i just wanna know before we buy the unit.thanks
Hello everyone,Is it possible to connect two WAP200E on bridge mode without external antennas if they are 200 mts. (219 yard) apart?RegardsLuis Noriega
Hello,I am planning to buy an access point (WAP4410N) for a meeting room office ...According to Cisco technical documents indicate that the AP is the only work in mixed mode (B / N / G) and supports remote administration with console Telnet (most imp...
Hi all,we are looking on how to power a WAP200E. In the datasheet it mentions it supports POE, however the customer does not have a POE switch and for one WAP220E is not willing to purchase.What other options do we have? Is there a power supply for t...
We have a customer running a RV 120W, and if the internet connection is disconnected it disables NAT, and you have to log on to the setup and enable it again. This is very annoying if the net connection goes down as you have to manually fix it, does ...
Hi Everyone,Please help me to understand some features of Cisco Small Business 300 Series Managed Switches. one of this is "Static routing/Layer 3 IP routing between VLANs allows for communicating across VLANs without degrading application performanc...
Hi,I am trying to configure my WAP410N with two SSID's on two different VLAN.SSID 1 should be using VLAN ID 1 and SSID 2 should be using VLAN ID 20I have a Cisco SG 300-28 switch wich I have configured with to VLAN, ID 1 and 20. ID 20 has port 20 and...
Hello please help me ..I have a big problem with my cisco wap4410n .. I have upgrade the firmware of this AP toV2.0.3.3 for supporting multiple SSID after my upgradation is finished ..one time I can able to access the administration pageBut when ...
So I setup two units in a cluster, the 2nd unit received all of the SSID's and VLAN info from the first unit, so all was good.Units have a DHCP reservation and are set to DHCP- <dhcp-client> <interface>brtrunk</interface> <status>up</status></dhcp-...
Hello,We have problems using routers wireless service. Very often we can not connect to wireless or other problem if I connected to my work network then there sometimes is no internet access. If I succesfully managed to connect wireless network after...
