Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi everyone...First, let me describe what we're trying to do. I work for a school system, and we are deploying mobile computer labs out to several of our schools. We have 11 such units currently in service with the following configuration:30 Dell L...
Hello,Very often router is hanging and can not access internet, web management page etc. Only solution is cold reboot.Already updated to latest firmware 2.0.13-K9, but problem is still here and router sometimes hangs.What could be problem?
Hi,I have two Cisco WAP4410N access points. Both has Regular and Guest SSIDs, with same configurations, except "Wireless Isolation" on Guest SSID is enabled.Problem is Guest SSIDs are not visible on devicesAccess points are working on different chanl...
Hello everyoneI have 4 WAP4410N sitting here to set up a 3 story wifi network. Since the WAP4410N is advertised as being able to work as a WDS repeater, I thought this might be a good product to allow users (only a handful of clients, around 4 or 5 a...
I would like to monitor the receive signal strength of our wireless bridge. Is this possible?I am already able to graph traffic on the interfaces, but that's as far as I've gotten so far.
Hi all,i have WRT120N and WAP4410N, can i config WAP4410N to be repeater to repeat signal from WRT120N??if it can't, could you tell me what kind of wireless router that compatible with WAP4410N?thanks so much..
Hi all,I didn't find any informative description about the following options:Wireless Isolation (between SSID w/o VLAN)Wireless Isolation (within SSID)Could you please explain clearly what does each option mean?Thank you.
Hey folks, I have about eleventy-billion WET200 wireless bridges out at client sites, and I am having no end of compatibility issues. With WET200 trying to talk to a ValuePoint MultiAP 700 or 770, I cannot associate at all, link quality stays at ...
Hello!I am using 2 WAP4410N in bridge mode with WPA2 Security.The bridge seems to be stable but i get poor transfer rates.Distance between devices ~ 8m - nothing between.Wireless networkmode: N-Only, Channel: Auto, Channel Bandwitdh: 40MHz (also trie...
We have a WAP4410N as a Access Point and a second WAP4410N as a Wireless WDS Repeater. The settings are as of below.Problem: We couldn't get the mobile users to get connected to the Access Point. But if we uncheck the option "Allow wireless signal to...
