Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
SirsWe are receiving an increasing number of complaints from our customers that their ADSL lines are disconnecting randomly.We have together with the country largest telco operator faulttraced the lines now for 2 week and the conclusion isthe the WRP...
I have a WRVS4400N v2 acting as a gateway connected to a cable modem and am interested in extending it's range by placing a WAP4410N elsewhere in the building to cover a deadspot. Is there a mode on the WAP to best achieve this (e.g., wireless repea...
Hello everyone,I am having 3 cisco wap4410n devices. i want to use them only in my home. i dont want to connect to internet. i want these devices only for intranet (only LAN) purpose. Means to transfer audio, video, songs through these devices. then ...
Hi, I bought several WAP4410N Access Points. One is used as an Access Point with two SSIDs.I want the other ones to work as repeaters for these SSIDs. Each time I use the option "Allow wireless signal to be repeated by a repeater.", the second SSID ...
A while ago I had posetd asking if anyone knew of an AP that would be able to wrielessly repeat traffic to my SA520W (so that the AP has no ehternet wiring at all). The answer someone had posted on here (or in emailt to me, can't rememberr) was the ...
Hi, new to the site and need some help. We purchased 4 AP1232AG access points, intending to use 1 as a router and the other 3 as repeaters. We've spent the past week running power to the repeater locations, installing poles and NEMA boxes, lightning ...
just wanted to know if the SA520W can wirelessly bridge (Workgroup bridge, WDS, etc -don't care which) to either an AP541N or AP1252... using WPA2-PSKthe 2 seperate examples would beInternet --->SA520W --(Wireless 30 feet) --->AP541N -->ESW-540-24P-K...
Ik have a 50MB/s internet connection and my IPS provider's modem out is indeen 50MB/sPer port from my router i do not get more than 20 to 23 MB/s ou tof it.How can I resolve this issue?
I have already setup the wds function for WRVS4400n so that its signal can be repeated. Then i also configured 2 WAP200 as repeaters.WAP200 A has the IP of 192.168.1.3 and WAP200 B has the IP of 192.168.1.4.The 3 APs has the WEP security setting on a...
hi there,we're using a WRVS4400n with V2.0.0.8-ETSI as Router and WLAN Access.- Network Mode: N-Only- Channel: 13- Secutity: WPA2- Isolation: disabled- Bandwith: 20/40- Signal is allowed to be repeatedNow we installed a new WAP4410n with 2.0.3.3 as r...
Hi there,I have two WAP4410N's and will connect them both to the same wired infrastructure to increase their coverage. I would like to allow roaming between the two APs. I know the roaming won't be seamless. My question has to do with the configurati...
I just purchased a WAP4410N yesterday and connected it to the switch. I can see the WAP4410N, can connect to it, but cannot connect to the internet. I thought this was enabled out of box. What do i need to do in order to activate internet connecti...
I have 2 7921G phones registered to a CUCM 7.1.5 server through a WAP4401N V2 running 2.0.2.1PID VID:WAP4410N-A V02Software Version:2.0.2.1Inbound signalling to these phones experiences serious delays - a phone that is 8-10 feet from the AP (i.e. 5 b...
HiIs it possible to use external antennas on AP541N set in WDS mode ?I would only need to use 802.11g mode 54mbpsI believe that the antennas shipped with the access points are removable RP-SMAThanks in advance for any helpDave
Hi all,I try to connect those part : 1 WRV210 and 1 EZXS88WBoth of them work fine. But, i can not see it on the network, even in wrv210 management console.I plug the cable in port 1 of wrv210 and then in "uplink" of ezxs88w. In the managment console,...
