Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
We are working on a lead where the end customer requires coverage in a radius of 50m in a few deposits with open shelves since their business is very specific. It is a pharmaceutical laboratory. and I consulted how we can document that this equi...
I need to update from older Cisco 350 Aironet 802.11a/b Wireless CardBus Adapters to Cisco cb21ag Aironet 802.11a/b/g Wireless CardBus Adapters in rugged tablet pc's. I need these without the antenna cap present to utilize the tablets antenna sytem. ...
HAI ALL;I HAVE BEEN REQUESTED TO MAKE A PALACE UNDER WIRELESS NETWORK COVERAGE. THIS PALACE COMES AROUND 3000 SQ.METERS. ONE HALL OF THE PALACE IS HAVING BROADBAND CONNECTIVITY ON WHICH WE CAN CONNECT A WIRELESS ROUTER. THE PRINCE WILL NOT ALLOW TO U...
First here is our network breakdown8 Windows 2008 Servers - uneffected5 Windows 2003 Servers - effected with dupe IP'sWe have AP - A, B and C all configured static and outside of our DHCP scopeA - 104.240B - 104.241C - 104.242WAP A is setup to allow ...
I have an Imerge SoundServer which streams music via my home network to various zones, including our Conservatory or Sun Room. My wireless network has evolved over the years. The link from the main part of the property to the Sun Room was originally ...
I have a new Aironet 1140N Access point , the model is number AIR-AP1142N-A-K9, my main problem in that i have Nokia E71 smartphones on the network, but they cannot connect to the Network, the Access Point SSID is not showing on the List of Available...
What makes my issue seemingly different from others is that the wireless radios completely shutdown after 25 hours. The V1 hardware was replaced by the V2 and still the same issue. I have swapped power supplies, moved locations to check for heat an...
Hi Team, Yesterday I brought one WAP4410N Wireless-N Access Point and successfully configured with out fail as suggested on getting started and I am able to access internet but unfortunately I am unable to access our local servers and services which...
Hi All,I would like to ask for assistance on how to configure one unit WAP4410N access point to work as repeater to one unit WRT120N wireless router.As a background, I had one WRT120N already in my house before I bought one WAP4410N as advised by a L...
hello people WRVS4400N a need: - For the wireless network can access the Internet and printers ( without access network folders) and do? - A network computer can only access the internet and printers (no access network folders) and do? Thanks Miéc...
Also experience this issue, latest firmware (7/17/2010 version). Definately related to large file transfers. Or, viewing videos (e.g. youtube) over RDP. Only power cycle gets responsiveness back. Laptops remain connected, but with "Limited Connect...
Hi,We just got a WAP4410n and cant seem to get multiple SSID's to show up when searching for them.Only SSID1 shows up in Kismet or any other type of Wifi detector software, is it supposed to be like this?I would imagine that it should display both SS...
Hi, My current AP infrastructure consists of Cisco 1242AGs. I've purchased a Small business pro 541n and need to be able to form a wireless bridge into my current network from it. In a lab I've configured 2 Cisco 1242 APs, one as a root brid...
Hello!I need to connect two dislocated wired ethernet cables (about 50 meters), so i bought one WAP200 (suport AP, bridge mode and repeater mode) and one WRV210.How do i need to configure the routers?I configer WAP200 as AP and in WRV210 configuarat...
We recentlybought a couple of these WAP4410N access point, I read the manual and accessthe web main console, which result a little confusing(really, really basicsetup for a Small Business device), I couldn't edit any wireless securitystuff, so I sta...
