Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello.How to configure the WAP4410N to use the DHCP server of my router? Or: how to configure my router tu let the WAP4410N provide ip-dns-subnetmask-gateway to all wireless clients?Thanks a lot!(repost from: https://supportforums.cisco.com/thread...
Hi;Is there a wirelss access point with all specs of the WAP4410n in addition to access control, URL blocking and denial of service support.Thanks,Reem
1. Is the product now stable as a basic firewall (SPI/NAT/DHCP)?2. Does it live up to its WAN to LAN thruput claims?3. Is there any limit to the number of concurrent DHCP leases from the basic unit (ie, does CISCO require (like Sonicwall) an upcharge...
My customer would like to have a secure guest wireless environment using AP541N's. When a guest laptop connects to the wireless I need the user to be redirected to a guest secure zone where they can only access the Internet after entering a password....
Helo, I need know if the WAP4410N is compatible with RSA Auto Manager for Wireless Autentication?Thanks in advanceRegardsFrancisco MarianoConstor Sales Engineer
have a WRVS4400n (v1) that I was given as a swap out to a different model. I was having problems with it's stability (intermittent conection issues, so I decided to upgrade the firmware from 1.00.12 to the latest available. I backed up the configu...
Hello,We have an installation of 10 x Cisco 1200 installation with a WET200-G5first we have installed the thin client with the wet200, no problemno problem with ping the thin client of wet200.now we connect a second device on the wet200 and they are ...
I was contacted by a client who runs a hotel with several smaller buildings spread across 1,5 km radius. They want to be able to provide wifi coverage for thier customers staying at the hotel and also for the employees. I've previously worked with th...
I have two AP541's, one which can be cabled to the LAN. The second one will not be on a LAN and I've enabled WDS and Clustering. Will I be able to take advantage of the Clustering capabilities in this topology? Will I be able to mange the second b...
I am able to monitor the 541N with SNMP, however the System Contact and System Location that I set on the system does not show up. When I query the device it returns "Unknown" and Unknown as the system contact and location. I have been awaiting a fir...
Hi i am vinaii am facing a problem, kidnly help me to sort it outNetwork DetailsBuilding Number 1 - We are having a network with domain serverBuilding Number 2 - We are having a network without any server ( connected thru switch to communicate each ...
Hi!I've searched and searched and can't find the answer to this scenario:Small Win2K8 domain with 10 workstations.Domain controller supplies DNS to the workstationsPrivate SSID for the owner's laptopHas access to the Win2K8 DC ( for DNS services and ...
I've just setup my WRVS4400N Router which went without a hitch! The WAP4410N Access Point on the other hand is a different matter. I've reached a point where I don't know if I am asking it to do something it is not capable of!Quite simply, I'm trying...
hi i am new to wireless so please help me out here..I was asked to add two wireless 4410n APs in a was that one acts as a hot standby for the other.as in, the user is unaware of the change in AP s...is this possible?if so,will someone be kind enough ...
