Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I need help with setting up a VLAN correctly. I have a WRVS4400N V2 with the latest firmware. Here is what I am trying to achieve:I want to setup 1 SSID for my office staff to access the Internet and our servers with and a second SIDD for visitors ...
For the next RVS4000 firmware, would it be possible to add a "mDNS Broadcast" checkbox to the Site-to-Site IPSec VPN Advanced setup?The advanced setup already supports NetBIOS broadcasts, which essentially lets the remote network see MS Windows-based...
Hi Team,I have got a couple of questions regarding AP541N antennas:1. Which type for the antenna connectors ? BNC or RP-TNC ? According to the doc:http://www.cisco.com/en/US/docs/wireless/access_point/csbap/AP541N/quick_start/guide/AP541N_QSG.pdf , i...
I have a question - regarding the new Cisco Small Business Pro 541 series AP, does anybody know the range/angle of the wireless "cloud" coming from the antenna?I have a 2 story office building that needs coverage. If I place the antenna downstairs ne...
Hi,I am looking to get coverage specs on a 1250 with an external omni-directional antenna, are there any specs sheets for distance in a clear line of site application for a tower mounted yagi or omni antenna connected to a 1250?Just to add to this, w...
5 v1 units here used across multiple different Dell PowerConnect gig switches in different buildings. All have the same issues described here. All are on the latest firmware 2.0.1.0 and it almost seems that made it worse than 2.0.0.12 was. I'll be...
Hi,I´m working with a Cisco WAP4410N to get wireless access to my network. If I configure the AP to use WEP, everything is working fine. All hosts get an IP-adress via DHCP.When I change to WPA, I do not see any DHCP broadcast message on my network, ...
We have a Cisco 871w as our main firewall/router/wap, and two WRV4400S units that we use strictly as WAPs. Call them FW, WAP1, and WAP2. The radio coverage of the FW barely overlaps with WAP1 and WAP1 barely overlaps with WAP2.I would like to suppo...
HiI have a WRVS4400N and it basically disconnects everything connected to it on a daily basis and the only way of re-connecting to it, is by switching it off and back on again at the mains.It is sat behind an orange livebox which acts as the modem; s...
hello,I've had this WRVS4400N for a while now, but suddenly (not long after firmware update 2.0.0.8 K9) I've had this intermittent problem of it simply shutting down communication between any port every 24 hours, almost by the clock - I can still acc...
"For 2010, I resolve not to crash every few hours..."Hi all, I haven't posted in quite a while, but have been watching. The revelations of a new hardware version with the implied admission that V1 is defective, an underwhelming 'new' firmware that on...
Hey,Recently tried to update firmware on our WRVS4400N (v1) router (from WRVS4400N_V1.0_V1.1_Firmware.zip), and ended up with router alternatively blinking the red Diag and the Power LEDs...Googled the whole thing...and tried resetting the router (po...
Hi ThereI have setup 6 WAP4410N's so far in three pairs. Each pair is acting as a bridge.While in bridge mode, and with the SSID Broadcast set to disabled, i am still able to see the default SSID (or whatever SSID i change it to) on my laptop when lo...
We have the WAP4410N and did a lot of configuration. When we use Kismet to look at the signal / traffic it shows our ip address of the AP. Is there a way to have the AP not display it's ip address?Thx in advance for any help given.
