Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Greetings -- I've just picked up an 881 and 2 521's. I have the 881 setup fine with the CP Express. No problem there. Now I'd like to get these 2 APs running but I haven't been able to figure out the first thing. I've attempted using the CCA to d...
i have cisco wireless controller 526 with access point 521 every thing work great but when i use cisco configuration assisstant software i can't view the access point in the toplogy view i only see the controller and the switch
Hey everyone, I was given instructions to get the log settings on the WAP4410N with the 2.0.5 firmware to stick. I verified they work and here are the steps I performed:1) login2) click on "administration"3) click on "log"4) check the boxes for ...
OK,I have not done the firmware for the units yet but have had only 1 outage thus far (but I think it was a power issue over the weekend).What I have done, 3 weeks ago, is put external antenna's on the 2 units which are 15 feet apart at 15dBi.The out...
Hi there,i would like to know if it's possible to turn this Access Point (AIR-LAP1141N-E-K9) to standalone mode.If it is possible, how can i do it?Thanks very much,(Pls someones answer as soon as possible, because it's to implement on a client)Rgds.
i have cisco wireless controller 526 with 6 access point 521 which is the limit for one controller how can i add another controller with additional three access point , the exiting controller with the 6 access point work great
Hello,I just bought a WET200 bridge to use at our university, which requires WPA2 compatibility. The settings in the WET200 under firmware v1.0.9 dont seem to have all the requirements, such as PEAP with EAP-MSCHAP v2 authentication, and it asks for...
My question is with the 521g(lighweight) acess point using the 526 wireless express mobility controller do you still need to run cat5 to the wireless access point? or is there just a power injector used and the wireless is controlled through the cont...
Sorry for the inconvenience folks. The link provided is delivering the wrong f/w file. Our IT staff is working to resolve this issue and should be fixed shortly. Again, sorry for any inconvenience this may have caused.
Hi everyone,I am reposting from this forum: http://www.linksysinfo.org/forums/showthread.php?t=59895From: DopfishHi, I'm having problems with the Linksys WAP200. When using WPA/WPA2 Enterprise the client hangs for about 60 seconds trying to obtain ...
We have a WAP4410N attached to an ATT DSL modem. The DHCP server is on our Novell Server. Wireless laptops connect to the AP and are assigned an IP automatically. The problem is that the connection drops, and the new IP address is not from the correc...
Hallo !Ich brauche dringend Hilfe beim Versuch, 2* WAP4410N AccessPoints im Wireless WDS Bridge Mode in Betrieb zu nehmen. Was ich auch unternehme, die maximale Verbindungsgeschwindigkeit, die ich mittels IPerf messen kann ist 20Mbit, selbst wenn be...
I have two Axis 207W 802.11g IP cameras that cannot see the SSID being broadcast by my WAP4410N when in B/G/N mixed mode (choice of security, channel, etc don't appear to matter) but can see the SSID when the WAP4410N is broadcasting in B/G mixed mod...
Hi to all,I have 6 APs 1131AG ( in LAP mode ) and Cisco Controller 2106. I configure it and all works fine... Now I need to downgrade 3 of AP to Autonomous mode and try it using:config ap tftp-downgrade tftp-server-ip-address filename access-point-na...
