Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I have an xfinity X1 router, broadcasting wireless, and 2 WAP 371 all on same SSID. I have some coverage issues and purchased three 240AC to implement a mesh (i have three of them) and have a few questions before I get started: 1. It would be very ...
Hi All In the process of 'upgrading' from WAP571s to the new Small Business APs. We have a 240AC as our Master. All devices reconnected without issue except for the sole Android phone we have, which happens to be mine! Having spent days working it th...
Hello, I was reading the administration guide of CBW series, but haven´t found any information about airtime fairness feature. Is it currently supported? If note, does anyone know whether it will be available in a future release? Regards
There are seven WAP571-E-K9 V02 ( FW v1.1.0.3 ) on SG220-26P ( FW 1.1.4.8 ). When i setup first WAP ... create new cluster ... my SSIDs, login/password - all is done . When i expanse cluster with second WAP all is good too . When i add third WAP i se...
Hi all,I have a radio schedule that turns off Radio 1 (the 5 GHz radio) at 11pm but keeps Radio 2 (the 2.4 GHz) running. The same schedule turns Radio 1 back on around 8:30am.The problem is that when the 5 GHz radio turns off (or on), the 2.4 GHz rad...
HiIs it possible to "mesh" WAP561 access ponits together to get a large wifi network without cabling ? I'd like to connect one AP to my network and the install other access points linked together to extend this network without cabling. If this is pos...
I have a WAP150 that I was doing a firmware upgrade on. The firmware was at 1.0.0.16. The upgrading it to 1.1.1.0 The upgrade was being done with the WAP on the network using POE as opposed to direct power connection. I started the upgrade and aft...
hello, i am looking for the firmware with the latest patch level for the AP "Softwareversion: AP541N-K9-2.0(4)"does anyone still have the file? Cisco no longer has them, i even called Cisco.Can someone help me? Greetings Heiko
hello . i have bought 3 cisco wap 361 . firmware 1.1.2.4 . i have connected them to tha same lan network 10.0.0.139, 140, 141 . i want to use them in roaming mode so users can travel through the office and dont loose connection or have connectivity i...
Hi, I have two WAP150's in a cluster. I want the AP's to run PoE. I have Ubiquiti 24W injectors, however the AP's do not start. Is there some kind of settings I can change or check to see what is the cause of this? Thanks a lot.
I need to set a static IP to my NAS, printers, etc.
First step: On Static DHCP menu, I see that VLAN has a combobox with the defaul VLAN (see file 01.png).
On DHCP Leased Client, I see my devices (file 02.png) and I flag my choise (file 03.pn...
Good Afternoon All I'm having some issues with a cluster of (4) Wap 371 Ap's, the connect speed is simply intermittent. One moment I can run a speed test (to the internet) and get 75mb down, wait for that test to run through and restart it again an...
Hello I need to replace 3 wap371 access points. Currently there are 2 ssid's broadcasting on each access point. I have all 3 access points connected to a single switch and have one of the access points configured as the cluster controller. If I we...
We have a Cisco CBW240AC as our WAP. We just rolled out Microsoft Teams as one of our meeting solutions (we also use Cisco WebEx). In the Microsoft Teams Admin Dashboard, it is asking for a WAP BSSID. Is this the same as the SSID or something else I ...
When configuring the WAP150, I can not assign a password to the wifi.Every time I put a password to the wify, when trying to connect afterwards, I got respond: Incorrect password.I try the 2 option of the security and this happened in both of them.It...
