Small Business Wireless
Helpful support links - emulator, video tutorials, support pages +
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
CoreyP319 by Cisco Employee
  • 990 Views
  • 0 replies
WAP571 Cluster Issue
I just purchased 4 WAP571 APs to use as a cluster, 3 of them are working great, when the 4th is joined to the cluster any client that connects to it is unable to get a IP address from the DHCP server.  If I reconfigure this AP to not be part of the c...
WAP571 April 2019 Firmware v1.1.0.3
I just upgraded 7 WAP571s to the new firmware from 1.0.2.6. While it works, I did notice some problems. I list them below. 1) Administration   a) Time      i) Set for UTC-06:00 USA (Central)     ii) Current Time display shows 5 hours ahead (current U...
comprev by Beginner
  • 999 Views
  • 3 replies
Cisco aironet 1815i can't access to mobility express in spite of AP Image type and AP Configuration : MOBILITY EXPRESS CAPABLE
I have setup  Cisco Aironet 1815i with Cisco wireless app for provisioning then I can connect to SSID normally, But can't access to mobility express, I try to connect with ssh with DHCP IP of AP  (I don't know why this IP difference with IP Managemen...
Access Point Reboot
Hello Cisco experts,I  have an Access Point Cisco AP541N, working great, except that every 1  or 2 weeks, clients cannot connect anymore to it. I need to reboot it.I recently updated the firmware to the latest version (AP541N-K9-2.0(0)), but that did...
WAP561 Access Point and external Radius Authentication (Windows Server NPAS)
WAP561 Access Point and external Radius Authentication (Windows Server NPAS)Hi,I've troubles on configuring Radius Authentication AP: Cisco WAP561Radius Server: (Windows Server 2016 - NPAS)I've configured an Access Point Network with Security (WPA En...
