Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello Experts,Issue - Users not getting IP only on 1 SSID for particular period of time. Time is fix. Not specific to Peak hours. SSID Details - Guest SSID - Corp.guestAuthentication Type - 1st PSK (Locally configured on WLC) then 2nd Web Auth (on RA...
Hi All,
We have multiple sites and have started to purchased WAP 150's instead of the 321's. We have used 321's for a long time and were great. The 150's are very similar and so we have now been setting those up. On two sites our 150's have been lo...
Hallo,I have a switch SG350 with its basic configuration, I am still building my network. In the meantime I got WAP571 which is directly connected to the switch. I did initial configuration and I can connect to access point but there is NO INTERNET A...
Hello,My english is not very good, but I will try.I have a WAP121 Wireless-N Access Point with PoE and I have reset it by mistake. Therefore I only have a wifi signal in half of our house. As far as I can see, I have to configure it all again, but in...
Currently, i have Cisco 877w with IOS flash:c870-advsecurityk9-mz.124-4.T7.bin, I need to upgrade IOS c870-advsecurityk9-mz.124-15.T6.bin or newer version.
I cannot download from cisco website because end of life & support. I have contacted Cis...
Hello, I want to configure the following case for WAP150.WAP150 is connected to the main network via a wired LAN by a DHCP server.And WAP150 builds independent VLAN / SSID in each of 2.4GHz and 5.0GHz.In addition, each VLAN can be connected to the ma...
Hello all,
I am aware that it is not possible to mix different WAP models into a same cluster. But what about WAP571 and WAP571E : both models are very similar so can I mix them both in a same cluster ?
Denis
Hello I have just purchased a WAP571 and a WAP571E. I run through the setup of the 571 and create the cluster and the wireless network ect. Then I run the setup wizard on the 571E and have it join the cluster. It appears that it has but neither AP...
I've been configuring a fairly large number of Access Points using the clustering feature and it works well except for SSIDs that have a vlan tag other than 1. Those VLANs aren't being created on the other Access Points, I've had to add them in manua...
I've just upgraded my WAP-125 to firmware 1.0.2.0, and then I've no longer access to the device via the web interface. Nothing happen after entering login and password. I've performed a reset to factory settings, the problem remain the same. Is there...
The WAP371 has the ability to enable the QBSS Load IE, but the WAP581 doesn't. This feature is needed for a list of reasons, including: 1) understanding how many clients are associated to a radio, 2) understanding the channel utilization, 3) aiding s...
I seem to have an issue with QoS on a stand-alone configured WAP361 AP. With WMM enabled, the client connected to the AP shows a data rate of 866Mbps on the Monitor/Clients page but actual TCP download speeds for some reason do not exceed 1Mbps. When...
Hi,I have 4 WAPs (three 150 devices and one 361 device) running the latest firmware 1.1.1.0 released on 08-20-19. But currently there are no updated MIB files to support the devices, on Cisco Software Download the only files available are from 04-14-...
HelloI have more than 10 WAP 4400N the problems I meet the most1-the wifi signal is good but no one can connect this AP refuses any connection saying that the « password is incorrect » when I disconnect the ethernet cable (POE) and I connect after a ...
Hello everyone,
After a whole lot of testing (years of work!), I think I have finally figured out the best configuration for WAP series. By default they have some problems with Apple devices disconnecting every couple of minutes, with Airplay and so ...
