Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I have a router I am trying to determine the model number of so I can determine what the specifications are of the wireless componenet of that unit. However, I can't get access to the Model number, only the serial number. Trying to determine which ex...
I am having problems with 5 Cisco WAP321 devices all failing to give clients DCHP addresses throughout the day. The wireless device is able to connect to the Access Point but is never given an IP. If I reboot a given Access Point then the same wire...
I have a WAP121 that only supports 2.4GHz.
I replaced it with a WAP371 for the 5GHz and the speed is much better.
Problem is, we have an HP m475dw wireless printer. It worked fine on the WAP121 with WPA2-AES.
When I set up the WAP371 identically, the...
I'd love to know, what are the main differences between WAP371 and WAP571?So far I think it's:- More powerful CPU for more clients (WAP371 had issues packet capturing for instance)- 2 LAN ports for > 1Gbps throughput (WAP371 was around 950Mbps becaus...
I have three WAP571 that I had been using as a cluster without much issue. I updated the firmware from the original 1.0.0.15 to 1.0.1.9, and I almost immediately started having issues with throughput on any connected device. I started over the clust...
we are about to purchase a few WAP571. On the Online Emulator Website I can see that the WAP581 (ver.1.0.0.4) has allready the new Web GUI and I was wondering if this is planned for the WAP571 as well. The current WAP571 (ver.1.0.0.14) still...
Dear All,
We have three CISCO WAP 321 Devices, which are having a same configuration. we have 192.168.0.x, 192.168.1.x,192.168.8.x networks. Device's are configured in 192.168.8.x network.
1) 2 SSID is created on each device.
2) SSID password, Chan...
Already setup the captive portal and created username and password to authenticate locally.
But when I connect to Wi-Fi, captive portal authentication page appears asking for username and password but when I enter the credentials, it gives authenti...
We tried to update our Cisco SG300-10 to latest version 1.4.8.06, since then the system is completely dead, after the upload in HTTP/HTTPS mode the switch turned off all Ethernet ports (without rebooting) rendering the web console innoperent...
I've just bought a used WAP571 Access point. I have upgraded it to the latest firmware; 1.0.1.10 but FindIT is reporting a firmware upgrade is available. The suggested upgrade is version 1.0.1.9
I can't get the ACL to work on my WAP 150.
Even if i just add a permit all on the ACL it still dosnt even let me get an IP address.
Any ideas to what i might be doing wrong?
PIC: shows the acl i have been testing with.
I have cisco wap 150 device and I have configured static ip adddress on the LAN
192.168.200.1
connected the laptop directly to the access point on lan interface (192.168.200.10) and trying to ping but cannot !!!
I have configured ...
Hello All,
I have been asking this question within another discussion thread, which got resolved without actually answering the initial question:
https://supportforums.cisco.com/t5/small-business-wireless/wap371/td-p/3089888
It has been over a ...
I'm in the process of setting up a HA pair and I' am unsure about a couple of things.
We have already got a standalone 5508 and I'am currently setting up a 2nd 5508 for resilience.
Both Boxes run 8.2.100.0 IOS.
1. Does the service port IP...
