Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello, We have setup two factor authentication (2FA) for our wireless networks using these devices. We have tested with a DUO radius server that uses a phone as the second factor. While it works fine you have less than 7 seconds to approve the reques...
I was having this issue with my Dell Precision M70 laptop until I made this tweak to the Intel Pro Wireless 2200BG card that is built-in and so far its seems to be making a difference with it connecting to our Cisco 541L APs and acquiring a DHCP from...
I purchased seven WAP561's to use in a cluster in our warehouseone of the WAP561's only seems to have one radio (the 5GHz is missing)see picture attached of two admin pages of two different unitsI don't seem to see any setting to completely disappear...
Hello All,I am currently in the process of setting up a Guest network on our WAP561. The main aim of this task to create a Guests network that visitors can connect to without a password and navigate the internet, but not connect to LAN devices.I have...
We have a cluster of WAP371s, and I'm trying to get them to do MAC authorization against our RADIUS server. I've configured the RADIUS server on the APs, and for the one (of our two) VAPs (I only want one of them filtered) I've set "MAC Filter" to "...
Hey,we have a problem with a couple of WAP4410s(WAP4410N-E V02), they lose their network connectivity after ~24 hours running.The AP's have the latest firmware(2.0.7.8) and only factory settings are used.When we shutdown the switchport and activate t...
Hi everyone, Today, i get a problem with the autentication of a WAP 561 and the role network policy server. My WAP 561 is connected to the Radius Network Policy Server role with EAP MD5. When a user of the domain want to connect to the captive portal...
We have 3 WAP121 APs configured as singel Point Setup all seems to work.
Today i thought I would check the settings and update FW.
But i cant open the web configuration page on any of the 3 APs. Only get timeout.
Tried using the IP addresses and Ci...
Hi Community,I have a problem with access point WAP321I have tried to hard reset it but it not responding and when i plug it via ethiernet cable it shows unpluged on my pc the only led working is the power it's flashing and other led not lighting whe...
Hello,I would like assistance with the parameterization of a Cisco SG200-18 switch. Indeed I would like to create three separate VLANs to distribute from the internet to three companies that do not have to interact in it or with my personal network, ...
For a lab i need to setup a Cisco wap551 in a smal network with cisco router 2921 and cisco catalyste 3650...
But when i connect my cisco 551 to any port of my switch after a few seconds the port is deactivated...
I have been trying for a week bu...
I am trying to replace a Cisco WAP371 with a WAP571 for my office.
I have connected the 571 to the same LAN cable from the switch that is used for the 371,
and I have configured it the same as the 371. When I complete the configuration wizard
and su...
I want to monitor traffic on wireless device (childrens's tablettes); I already know the mib (SNMPv2-SMI::enterprises.9.6.1.32.4410.1.3.3.3.1.2.1.1 ) to retreive the associated mac adress; but I need to understand how to get the traffic generated for...
