Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi everyone,
I just discovered the hard way that 8.3 breaks the SNMP agent. The rest of the engine works just fine meaning traps but the agent piece is totally dead. Time out on all 3 versions. As if UDP 161 is dead. Agent debug does show incoming pa...
Hi Every1
I have purchased by mistake AIR-SAP1602I-E-K9 instead of AIR-CAP1602I-E-K9
Now I need A Controller for This .
I will be very much thankful to u all, if some one can suggest me any Controller which support AIR-SAP1602I-E-K9
I Having Very T...
Hi i am using cisco from last 2 years today some one has reset my device now it is not a secure network
i am trying to make it secure again wirelessly but it is asking for pin which will be consist of 8 numbers
i have checked my device may b it conta...
Hi to everyone,
I am new in this forum.
I have installed the WAP4410N and SRP547W. The SRP is configured as wifi router. Here I have configured three wifi SSID: one for normal traffic, one for guest, one is dedicated to printer.
I work with a LAN p...
We have devices that keep losing connection to the Wireless network. Usually during a conference. It happens multiple times. Nothing has changed on the network, and everything seems normal.
A macbook pro is what is connecting to the wireless net...
Hi Team
I have three cisco WAP 121 access points. I have 250 Mbps dedicated line. These access points are giving less than 40 Mbps speed only. I have another HP access points. It's delivering up to 100 Mbps to 110 Mbps. But Cisco AP's give only 20 to...
Hello , we have several Cisco Aironet 1130AG.
The problem is that when we connect to them the speed is very slow. About 8Mbps on download speeds ( on wired its 50 Mbps). On apple devices the web browser is very very slow
The config is this:
enable...
Our company purchased 40 item Cisco WAP 321 and using with 12V 1A adapter .Then we are found big problem when disconnected Network cable after 5 minute automatic Device not working (All LED are closed ).May i know how can i solve current issue.
Best...
We are computer resellers and installed three Cisco WAP361 access points at our customer. These 3 access points were configured as single point setup and we activated 2GHz and 5GHz bands.The problem is that our customer equipaments are Apple (iPad, M...
Hello
Please I have antenna 14dbi directional and AP 1572EAC
I want to know what distance can this Antenna provide When I connecting Two APs ( RAP & MAP) ???
Please If anyone tried this before or have information about this Help me
Grateful ...
I have Cisco 1602 AP. I am planning to have the wireless users connected to this AP so that when they access Internet, it should prompt them to enter the user name and password on their web browser. This is is similar to Captive Portal but i wan...
Hello Mates,
I found lots of articles about issue with WAP371 if use VLAN tagging to WLAN.
Looks like this issue is still not yet resolved. I installed latest software 1.3.0.3 on WAP371 and all iPhones, iPades and macbooks are really slow.
Speed...
Hey Guys,
I am testing out new software k9w7-tar.153.3JD on an Aironet 1261n but it keeps crashing. I cannot do things like write, copy running-config, etc. These command crash the device immediately.
I am no expert with Cisco devices so I am wonde...
Hi all,
is there any instructional information as to the steps to be taken to reload the OS of this Access point. I have searched all over the place but nothing .
Please help
J
