Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Currently have a Cisco AIR-LAP1131AG-A-K9 Aironet 1131AG Wireless Access Point. The Cisco LAP 1131 does not have an independent controller & is being used to create a WiFi signal from an Asus router. I wish to receive that WiFi signal, at a distan...
I have two WAP321 access points clustered.
When I upgraded the firmware to version 1.0.6.2 the below errors began to show every time I clicked on Access Points or Sessions under Single Point Setup.
I reverted the firmware back to 1.0.5.3 but t...
Updated firmware on Wap371 AP to 1.2.1.3 (2 in the cluster) now the 2.4ghz wireless speed is virtually gone or really slow but upload is the fastest it's ever been. The 5ghz up/download speeds are also the fastest we have had its just the 2.4ghz down...
In the Cisco findit side bar i have a WAP121 that is showing as warranty expired, i know this cannot be the case as it was just installed and assume it is an error in the software as it is showing the date of 1972.
Does anyone know how to fix thi...
Hi. I am a beginner in a new company and have a problem with one device (Gauge Testo Saberis 2) in a cluster from 4 Cisco WAP321.
The device has follow requirement :
2,4GHz 802.11.b/g/n2. WPA2 AESThe device connects shortly (1 second I assum...
Dear Experts,
I have a TP-Link 3G/4G wireless N router and I need to form a VPN server on this router in such a way that all my remote android and IOS mobile users should be able to connect to the this wireless routerusing the inbuild VPN options ava...
Hi, we have made an upgrade of our WAP321 firmeware today, but after the reboot the device wasn't booting again. Only the Power LED is flashing green (2 seconds, off, 2 seconds....) an if we plug in a lan cable the LAN LED is flashing amber. So far w...
I have wap321 config and cat 2960 as attached.
my issue is, if I configure native vlan160 on trunk,I lost the ping and web gui to wap321 although I have assign management vlan on wap321 to vlan160
and uncheck untagged vlan.
is this a normal behavi...
I try to set up an captive portal for my guest wlan.
Everything works so far, as soon as I connect it shows me that captive portal.
Now I changed setup: Captive Portal -> Instance Configuration -> Verification to "Guest"
Because I want that guest...
Hello Cisco,Now Im a big Cisco fan so i replaced our Airport access points in the house with the WAP561.My main problem is that since i did that, once in a while (if i had to guess every couple of hours) I have our laptops, iphones disconnecting and ...
Cannot connect to it neither through ethernet nor wifi. Seems like crashed after pushed reset button for 40 seconds. Also tried Cisco FindIt tool with no success, off course sinds I cannot get a connection with it. No lights other than the pwd button...
Dear Community,
I have 3 WAP321 access points. I am able to setup a single point for 2 of them. When I try to insert the 3rd one (with the same AP name of course), it remains by its own without joining the existing one...
The 3 have the same firmware...
All,
Some strange behavior is occurring.
Was working for the last 9 months great, but here is the story.
Environment:
ASA5516-X, ASA5505,ASA5510
*Tried all three thinking it was a firewall problem.
WLC5508 and 17 AP3702i
Catalyst2960 Switches
Rec...
