Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Dear All,
Please help me on my Wifi Issue,
Im experiencing slow (half) speeds when using the WAP4410N.
please send me an email for the solution: jonel.aringo@hotmail.com
Jonel
Hello Gentlemen
can any one help to to find the appropriate power injector for the access point 551 i tried to find any valid part number but without any result
Hello
I need help with configuration of me new WAP561 , i created guest ssid and configurated captive portal with local authentication. It works fine but i need to isolate guest from company network. In our company network we use SG300 and SG500 swit...
I have a WAP371 on my network set up as a wireless bridge, DHCP function is handled by my RV325, and the wired network works fine. I've had this setup for several months now and about 2 weeks ago after constant use, the WAP371 stopped responding, di...
I have just purchased this unit and am struggling with the guest vlan. I have configured the unit with the wizard, set up guest vlan (30) , connected that to a vlan aware switch (GS110TPv2), plugged the AP into a port that tags Vlan 30. The router co...
Is there a way with the WAP371 to force a client to use a particular WAP?
I have 4 WAP's throughout my house. My Ring Doorbell wants to connect to the WAP in my office for some reason even though the signal is stronger for the WAP in our living room...
Hello, i have setup'd 2 Wap 371 in a cluster and captive portal for our guest users. When a user moves out into the 2. Accesspoint a new authentification pop's up to do a re-login. Does the 'auth client' settings are not moved over to all cluster AP'...
I need to know the draw in amps of the Cisco Aironet 1570 Series Outdoor Access Point. I am the electrical installer & must know draw in amps prior to designating circuitry for this item
Please advise,
Thank you,
Jeff
Hi there,i have to set up a WAP321 with captive portal and radius-authentication against a microsoft nps.Unfortunately the nps gives me the error, that the eap-type is not correct.Can anyone tell me what type of eap the WAP321 uses?ThanksAndreas Koch
Looking to setup 3-4 WAP4410N AP's but only want to use 1 SSID and one set of keys if possible. Is this possible with these units and if so can anyone give me some direction/ help on configuring them properly??Thanks in advance.Mike
I bought six WAP351, upgraded all of them to the latest firmware (1.0.1.4) and tried running them in a cluster. I have discovered a problem with distributing/passing DHCP addresses to clients.
All six AP and dhcp/log/etc server are connected ...
Hi everybody,I have a problem with my Linksys Wap4410n regarding some disconnections...I configured it with wpa 2 personal password, access point, b/g/n mixed...So a normal access point configuration and it works well when I use the default firmware ...
Hi All,
Quick question for you. I have two wireless lan controllers at different locations: at Location A:WLC2125-K9 licensed for 25 AP's, and at Location B: WLC2106 licensed for 6AP's. I appreciate these are end of life and the best recommendat...
How does this work? Do you have to make your own page or are there any "canned" pages to use? I'm assuming you put the appropriate UR, in the redirect section? Sent from Cisco Technical Support iPad App
When I enable wireless multicast forwarding the IGMP queries from my router become suppressed you the WAPs. Multicast will flow because the IGMP report from the client is passed to the router, but since the client doesn't receive the queries from the...
