Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi Guys, Before i started in my current job that had arranged an IT company to put in a new Server etc. During this process they put in two WAP561's (WAP561-A-K9 V01) in a cluster. Emits 2 SSID's 1 x a/b/g/n and 1 AC. Previous to last Thursday they w...
Greetings,We have a Cisco WAP561 for our organization that keeps randomly going down. I can't find any commonality in each of the cases. The following are the symptoms:1. All connections are dropped, both networks from the WAP become undiscoverable.2...
There are times I have to power down the WAP 321 Wireless Access Points, for building maintenance and other activities. Once powered down, when power is restored, here is what happens:
1) The power light comes on
2) The network light flashes
3) The ...
Hi.
I'm having som troubble setting up two WAP371 in a Single Point Setup Cluster.
I have enabled SPS on the 1st WAP and then I run the setup wizzard on the second one and choose "join existing cluster" and type in clustername. It then says everytin...
I have two Cisco routers, one RV215W which has a wired internet connection on the WAN port. And one RV130W which I want to function as a repeater for the RV215W since I'm not able to provide a wired internet connection but it's in the wireless range...
I need to mount my WAP 561 to a drop ceiling with recessed ceiling tiles. The provided mounting bracket would work for a dry-wall ceiling, but not for a drop ceiling.Any suggestions or tips on doing an attractive install?
Hi,On all switchs access, the spanning-tree add strange value when I create new Vlans from Distrib Layer,and no association is created with any interface with spanning-tree vlan 700, see below in this exemple,until I reboot the switch.somebody alread...
I've deployed the WAP371 at 4 different locations. Each location they are setup with the latest firmware 1.2.0.2 and are in cluster mode. At least 1 or 2 times a week, each location calls saying they connect to the SSID network but have no internet...
I'm running into a problem with my WAP321. I have two if them onsite for a client and one is working perfect. Just finished upgrading the firmware and it came back to life.The other one I use for the poffice upgraded to 1.0.5.3 without a problem but ...
Hello, We own several WAP321 which work fine. For our site expansion I now purchased a WAP371 for the dual-band capability. To test it and set it up, I just replaced one WAP321 with the new WAP371. The device came up fine (both radios disabled). I f...
this error below shows up on my log many timesmDNSPlatformSendUDP got error 126 (Cannot assign requested address) sending packet to FF02:0000:0000:0000:0000:0000:0000:00FB on interface 10.20.30.4/brtrunk/8,size of to is 16,socketsize is 2
Hi everyone,Is it possible to form a single point setup cluster with a WAP 321 and a WAP 371 ?For now, both APs seem to not see each other.Thanks you in advance for your answer.Mathieu.
The Captive Portal modification is limited in how you can change the page design. First, is there a way to make the page more mobile friendly so my users do not have to pinch/zoom in order to read the page and terms of service? Using these devices fo...
