Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello,I am setting up a new network that will include at least 3 but as many as 6 WAP321 Wireless Access Points.I used the wizard to set them up and all seemed well. I then went in to see how effective they were and discovered that the only differenc...
Hello,just implemented two AIR-SAP2602E-E-K9 as bridge-pair with directed antennas.When using the "show dot11 ass all" command, I can see the actual data-rate on the air. But this models show something like m7b2 etc.Can somebody give me an explanatio...
Hi,I'm currently having a bit of trouble with a couple of WAP410N WAPs.The problem I have is that the WAPs drop out and can't be connected to. They become completely unresponsive and I have to reset them.I have a couple more of these WAPs, that are w...
Hi AllCurrently have a case open with Microsoft as we are having radius authentication issues through our WAP 321 devices. We are trying to use MAC address based authentication by creating AD accounts and using network policy sever but MS documentati...
We are a small business and we are using WAP300N as an access point to which about 40 devices are connecting daily. The AP is connected to a RV180 Multifunction VPN Firewall Router. Since we have this infrastructure, every single day there are client...
We are receiving lots of drop outs on our WAP321. My line manager is asking why I insisted in getting a Cisco unit, and I'm getting it in the neck from all the users, so I'm reaching out to the community for some help - I hope you can assist.Nobody...
Hi i have a problem with my WAP321.Sometime in the day, i loose connectivity to the network.My laptop shows that i'm associated with the access point. I have an ip address on the interface, but i'm not able to reach anything on my network.I have to d...
Hi All,Setup a WAP321 with the new 1.0.1.10 firmware. Setup 2 SSIDS:WIRELESS (vlan:1)GUEST (vlan:99)The wap is plugged directly into a port on my router so I configured the port and additional vlan99 port. I have a DHCP scope assigned on the router t...
HiWe have a Cisco WRVS440N (running firmware V2.0.2.2-ETSI) which is used for wireless connectivity to our network.Over the last couple of days we've noticed that if connected wirelessly through this device, occasionally you will not be able to ping ...
I am struggling with wap321 captive portal. tried a lot of configurations and still cannot get it to work. The portal authentication page just does not load. It always ask for the WPA2 password regardless it is enabled or not in the global configurat...
Dear Support Team
I have purchased, cisco wap 321 2 days back and configured it. Problems I am facing are
1. Clients are not able to connect to it. If they get connected and get an IP address from DHCP server. They have frequent disconnection.
2. U...
Hi, after we upgrade our controller AIR-CT2504-K9 to software version 8.0.100.0, only ReadWrite user can login and view SW management, the LobbyAdmin receive an error:https://172.25.2.1/screens/preframeset.html --> Non riesco a visualizzare questa pa...
Hello CiscoI have a brand new WAP561 out of the box, i installed the 1.1.0.4 firmware and set it up using only one radio set to a fixed channel (104).After a while my clients loose connection to the network.I then looked at the setup again, i seems t...
Hello, I'm triying to configure four AP WAP121 in WDS mode but I am worried.The firmware version is 1.0.4.4 ; each AP have a static IP address in an isolated network (VLAN 2). Each AP transmits two wireless networks :- Network 1: - VLAN 10 - SSID: ...
