Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello everyone. We have 18 AP541-Ns and 2 WAP551s at our office. And we want to use them by cluster. My question is that, can these Access points support each other? If someone have any idea on that, please assist us. And another one question:They ca...
we have 6 WAP4410N-E V02 devices working, but periodically they stop working and after reboot they work again, maybe because there isn't traffic?.Last firmware installed (2.7.0.4). Any workaround to solve it?configuration?
Hi guysI have a WAP121 AP, and i want to be able to setup a guest SSID along with my full access SSID. The guest network should only be able to access the internet.I have the AP plugged into a single port on a Netgear GS728TP smart switch.I know i ha...
Hello, I have two access point WAP561 with the last firmware ( 1.0.4.4). I have big trouble with apple Imac & Macbook.-Apple disconnecting-Bonjour Discover didn't work after 2 daysI must reboot every 2 days the AP for workaround the problem. I had tr...
WAP551 and Apple Macbooks - connections drop every 10 minutes. The Apple Macbooks are from 2007 till 2013. WAR551 are up to date and in cluster mode (3 WAPs).Here is a LOG from an Apple Terminal:>> associated to "YETU". Bailing on auto-join.>> Thu Ap...
I need to setup a wifi hotspot for my customers at my café. The size of the café is about 100 sq metres, and max number of users is 100, though it is likely to be around 50 on normal days.Is a single WAP561 access point sufficient for my usage, or sh...
I have 1 WAP321 for guest access.Now I need to isolate traffic of guest captive portal from my LAN.How can I do this?Thanks in advance.Sorry for my english
Hi Team, Working for the one of the Hotel project where we have considered WAP121 AP's for the wireless coverage part. WAP supports only single band. Now in a days their are dual band WiFi clients (iPhones, Anroide base smart phones -which supports d...
As the title says - I have a wap4410n acting as AP and a second wap4410n acting as wds repeater.I've only managed to get the wds repeater to work when it has a different ssid to that of the ap - I'd like the wds repeater to have the same ssid as the ...
I need to extend my wireless coverage to another building. What access points, in repeater mode, will the rv220w support? I need an AP with detachable antennas. I have an external mounted antenna on the metal building that I need to hook the AP to...
I have a SonicWALL running DHCP and two WAP321 Access Points. Mac and iOS clients will connect for around 5 seconds and then lose their IP address and use a self-assigned one. The wireless channels are set statically to the least used in our area. Th...
Hey there, looking for some advice.I currently have two (2) Cisco RV180W devices and im looking at expanding my wireless saturation within my house and looking for the best way. a bit of back story... I originally had a signal (1) RV180W and it was l...
Does the WAP 321-E-K9 (as 5GHZ frequency) supports the 802.11a?If yes, please specify exactly the output power transmission in dBm?Is it possible to have the 5GHZ frequency that not support the 802.11a? Because in the technical sheet of the WAP 321-E...
Hi Guyz, I am using WLC 2504 (Sysinfo given below), I created a new SSID on different VLAN, but when i used to connect to it while using previous SSID. Moving between two SSID is very slow. I have to disconnect my wifi then wait for 5 mint and then a...
