Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Dear All,I just create second SSID for different WLAN on my WLC 2504, all client other then Apple devices are successfully able to connect to new SSID a dnd can swap between two SSIDs but apple device unable to shift to new SSID, if any apple device...
Hey. I am currently setting up a WIFI-Network for a restaurant using the WAP4410n as Access Point with two SSIDs. One SSID is for Guests and the other one is secured and for staff.This second SSID should be repeated to properly supply the offices. Bu...
I have 3 Cisco WAP 2000 and have two SSID's set up with passwords. I usually change the passwords every 3 months or so, but now when I log in I can't even see where I can change the passwords. there is no longer a drop down list under Wireless. There...
Setup my WAP321 this morning. Unplugged network cable. Walked across the street, plugged in for deployment, dead. Tried POE from switch, from injector and even plugged power cord in, nada. How do I get it serviced? We just bought it 1.5 months a...
I am hoping that someone could assist me with my issue. I have been trying to get my WAP4410N setup. I had to do a hard reset on the device. I tried to connect to it via WIFI and the device asked for 8 digit WPS pin. Of course this is unavailable as ...
Hi, I had asked this in the Wireless IP voice and video forum, but someone suggested I ask here...-------------------- Hi, Just bought some 7925G phones. First time using these, obviously as I thought they were going to come with a base that plugged ...
I have 4 of these access points in a small office building. 2 on the first floor and 2 on the 2nd floor using POEAll 4 share the same SSID, auto channel selected, using WPA2 encryption. AP mode is set as default.My issue is the following:My Users and...
Customer has 6 AP541N model units in Cluster Mode. They are experiencing instability issues that require the AP's often to be rebooted. Firmware 2.0.4 is loaded. Anybody fighting similar battles and/or have any suggestions/tweaks that worked for t...
Dear All, Network- I built new Wi-Fi network with 70 devices (AP WAP121), at our hotel, inside the corridors of guests' rooms.- All AP connected to switches Cisco POE, and all Switches connected to Core Cisco switch, connected to DSL Router. Coverage...
Hi,So I am currently deploying a Wi-Fi Network based around Cisco WAP-321. I use the CP function with a Radius server to authentify my users. So far so good, when a user connect to one of the AP and uses his credentials, he can login and access Inter...
Hi,I need to determine if the WAP321is capable of supporting a configuration that we routinely perform on Enterprise Access Points in Autonomous mode (not connected to a Cisco controller). If you are familiar with Cisco’s Autonomous access point conf...
I am hoping that I can get some help. I have been trying to get my WAP4410N setup however, have had no success. I had to do a hard reset on the device, after that I began to have issues. I able to connect to the SSID it gives off after reset as cisco...
I am unable to get my WAP4410N wireless access point connected to my switch with an RJ45 connection to join my network because the 4 or 8 numeric digit PIN required by Win 7 and Win 8.1 is not identifiable on the router label. The network sees the WA...
Hi, we have two WAP551 AP's in our main office. I configured them using Single Point Setup, so they have the same information for the SSID's. The issue is that one AP seems to work fine but if I move in the range of the other it won't authenticate,...
There seems to be no 'save' to save the current running config - is that right? The docs say "For example, if you made changes to the current configuration but forgot to save it, after 24 hours, the device automatically saves the currently-running co...
