Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello,We have a network where Cisco WAP150 and RV110 Wireless Router roaming the same SSIDs which is same network, same vlan, same password and same security type. Recently, there is some problem in accessing other devices in the network. When we reb...
Hello,I have 8 APs WAP150 installed in an office since 11/2020, all feeded with POE from linksys SW 24 ports, this network considers as a secondary network in the office with its own IP range, some users connect with their mobiles or laptops. I faced...
Hi, I have several sites that have clusters of Cisco Business 240AC. These are configured with a management portal on VLAN1 and I can remotely access the management portal across the company WAN, however, due to recent shortages, I have had to use t...
HiI have a CBW 240 WLAN consisting of 16 number of AC240 model since One year,then I want to increase the coverage by adding more APs,I didn't found the supported models in local market so I ordered 5 ac140 pack online from US, I tried to add The New...
Hello,I am having major issues setting up a CBW140AC-B out of the box. I have it plugged into the PoE port of my router and per the instructions, I waited until it cycled to flashing green light. Then again per the instructions, I am supposed to co...
Dear Friends,I am running a single point setup of 6 WAP571 with 2 vlans, each using 2.4 and 5 GHz. Firmware is 1.1.0.3Now since a few days someting very strange happens every few hours or days: one or few of the APs drop out of the single point setup...
Hello all, In short: I have two Cisco Small Business AC140 wireless access points that get stuck flashing red after zero day setup. Neither will broadcast after initial restart. Both accept factory reset and bring up zero day setup. Specifics:I go th...
Hi.We have 3504 Cisco controller configured with a 1832 AP.Authentication/connection to the configured WLAN fails and we can see the following messages in the 3504 controller.*radiusTransportThread: Apr 07 09:00:51.379: %AAA-3-INVALID_REQUEST: radius...
Hello,I cannot update to new frimware version because certificate problem. Original message is "Connection faliure: 60, Peer certificate cannot be authenticated with given CA certificates."What can i do to obtain the new frimware version ?Thanks in a...
Just received a shipment of WAP125s and did a one for one replacement of some older WRT54Gs. I configured them for WPA Personal using AES. I have deployed 6 of these APs now - and no clients are able to obtain an IP Address through the new APs. No...
Is there a data-flow diagram or other useful description of the process involved in servicing a DHCP request from a wireless device? The WAP125 Admin Guide describes the meaning of various configuration parameters, but I couldn't find anything more ...
From the moment the device is pluggedd the power led trun solid green, and can't access via GUI and not spread WiFI siganl. is there another metod to load a new firmware image?
Hello, I have a cicso 145ac and I dont understand why it can read my sv jung servers ip adress but not my schneider knx ip router somehow. are there any more things to do.I wanted to use this as some kind of switch to reduce cabelingWhen the schneid...
