Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello CommunityI lost my password for a WAP551 AP.Now i start the factory reset. But it fails.After 10 sec. the Power-LED shows red and the accespoint reboot with the configuration.If ther a nother way to reset the password or reset to the factory co...
Hi All,I've tried to research this issue but can't find anything close enough to what I'm looking for. I have two symptoms that relate to the same issue. the first one is that when I connect to my RV180W through PPTP I'm able to access the entire p...
Hi, New to the forum. Thanks in advance for your help. Have been having some wireless connectivity issues the past few days. Started troubleshooting this morning and thought to upgrade my router firmware. Am using a Cisco E2500 on a Dell PC with Win ...
Hi allAfter replacing a AIR-AP1231G and a WAP200 (which both had external antennae) with cluster of two WAP561, I noticed that Wifi Analyzer (https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer) on my android phones shows lower va...
I am trying to do this thru the "WorkGroup Bridge" function of the AP.What I am trying to do it provide connectivity for a device that only has a wired ethernet. There are is only one drop in the room but on the other side. I have two WAP121, one con...
Hello,Sorry for my bad English, but I have a big problem with my WAP200E. It is a WiFi access point outside POE. Following a firmware update via the GUI WAP200E it is impossible for me to get to it. I waited 1/4 h, took the official firmware from Cis...
I just want to double check myself. Does the Maximum Associated Clients setting on the WAP321 cause the AP to refuse connections after that limit has been reached, thus causing the client to attempt to pair with another access point with the same SSI...
hello together,i'm running a WRVS4400N router with parallel WPA2-Enterprise and WPA2-Personal wireless networking. If I try to ping a host on the network I get two different results:The ping over the WPA2-Personal network is working pretty well.Over ...
Hi,Does anyone know if we can mix 2 WAP321 devices on a new Single Point Cluster, along with an additional WAP121 device?Hopefully this is very easy.Thanks!
Hello!I want to create a network that can separate the traffic between two or three VLANs. I want to be able to connect wireless using two SSIDs assigned to particular VLAN. Also I would like to be able to extend the wireless area using another Acces...
Hi!Are there any working configurations for ipsec with an iphone connecting to a rv220w? I don't want to set up an insecure pptp vpn...If there aren't any working configurations, will there be iphone support in future firmware releases?Best regardsRi...
Hello to allI have the following issue: I managed to configure the Wlan radio interface of a 1811W and I am using WPA2/PSK. But even I connect to the router via wireless it seems that there is no communication between the computer and the other inter...
Hi all...My company has an AP541N and it was working fine for about six months, but now roughly once or twice a week it just stops working and needs to be restarted.Whenever this happens, there are some log messages that look like they relate to the ...
Hi Guys,We are trying to connect a Linksys IP phone SPA922 / Bridge WBP54G v2 to a WPA 2 ssid.( Aruba)We are getting IP address and connected to wifi but no traffic SIP is seen on our network. All the settings seem ok. Phone is connected to the b...
Hi everyone,on my local network I try to receive a multicast stream with wireless clients (Media player / MacBook Pro) connected via two Cisco WAP561 APs. The APs are connected to Cisco SG-300-10 switches which have no problems with the multicast tra...
