Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
https://github.com/elvanderb/TCP-32764Nmap scan report for 192.168.211.124Host is up (0.033s latency).PORT STATE SERVICE VERSION32764/tcp open unknown1 service unrecognized despite returning data. If you know the service/version, please submit ...
Hello, I have recently purchased a RV220W wireless router and a WAP121 access point and i would like to allow my users to "roam" between the two networks as needed (so when the user is closer to whichever one they connect to that one since it has a b...
Приобрели точку доступа WAP4410N.Настроили, запустили в массовое пользование (пользователей меньше 35).Точка доступа периодически либо виснет, либо создаются большие задержки, либо перестаёт отвечать по беспроводному интерфейсу.В сислоге ошибок нет.К...
I appreciate that in the 2.4GHz spectrum North America is restricted to channels 1 - 11, however for the non-FCC "N" version is there a reason why channels 12 & 13 are completely missing ... other than "we forgot to include them in the firmware"?AP54...
Hi, I bought nearly a year ago two WAP321 and I'm having some problems with one of them. A couple of months ago I bought a WAP121 to increase coverage area of my WAP321 and I set up a WDS between 321 and 121. It works fine and the interfaces are up. ...
Hello All,working with the RV180W and a Ubuntu server I have established a FreeRADIUS server and have it setup for PEAP authentication based on a users file with NTLM encrypted passwords. This is working pretty well, however I have one problem. My ...
I currently have a WRVS440N v1 working with a WET200 bridge, E1200 router (guest wireless vlan 2) and SLM208 trunking to the router. I need to support another bridge location but the WET200 is EOL. Looking to clean this up but I want to keep the 8 ...
Does anyone have any expericne using Chromecast with the Small Business WAP's? We have a cluster of 321 WAP's that seem to drop the Chromecast conenction every 2 minutes or so then re-establish then drop in 2 minutes, etc.. Thanks in advance.
I'm trying to configure a WAP321 so that I have the same SSID and WPA2 password on both the RV220W and the WAP321 so that i can reach all areas of my clients location.I am unfamiliar with the WAP321 so any help is appreciated.
Hi,We have bought the Cisco Access Point Version "AP541N-K9-2.0" We are having the below issues while testing with the Access point1)Accounting-interim update request is not sent by the Access point for an active session2)Accounting stop request do n...
Hi.. We had bought the Access Point "Version AP541N-K9-2.0(2)".We tested using the above Access Point by configuring a new ssid.We observed the follwing issues :1)Accounting-interim update request is not intiated from Access Point and couldnt find...
Enovironment 7) AP541N-K9-2.0(4) Clustered 2) SSID's on VLAN1 WPA/WPA2/TKIP/CCMPI am finding that wireless clients (Phones, Laptops, IPads, Tablets, Etc) won't connect and get an IP address. They do authenticate with the wireless but nev...
We cannot access the "Wireless Network Setup (VAPs)" menu on our Cisco AP541N-K9-2.0(4) Dual Band Access Point anymore (see attachments). Please help. Thank you.Hello, we cannot access the "Wireless Network Setup (VAPs)" menu on our Cisco AP541N-E-K...
